who can guid me through body lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 06:17 PM
I'm working on a 69 dodge coronet and it has bodylines all over the quarters. how can I insure crisp strait lines?
Old 11-08-2005, 07:22 PM
milo's Avatar
point on positive
check this one from the other day... body line
Old 11-08-2005, 07:49 PM
thanks.
I actually read that post a while back but it looks like its been added too.
Old 11-08-2005, 09:40 PM
As you prime and block and prime and block the surface your lines naturally become more defined and sharp. The contour of the panel determines if they are straight. If you have a shallow wave near a line the line will follow the wave. So get your metalwork as straight as possible with good panel alignment and then block to perfection. Using a guidecoat you can block one plane of the panel and the straighness of the line will be easily visable, in other words-block one side of the line then the other. Hope this made sense, much easier to demonstrate than describe. Bob
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
Model A body dimensions Help! NZ30Roadster Body - Exterior 3 02-19-2005 07:52 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 09:59 PM
body filler and black paint oldred Body - Exterior 13 12-18-2004 10:34 PM
How flexible do cooling lines need to be? McDeuce Transmission - Rearend 3 03-22-2004 01:36 PM
