Who has built a Procharger SB Chevy-Step inside!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2011, 10:15 AM
Hello-
I recently built a 383 Chevy and now want to put a Prochager on it. Currently the block is .060 4 bolt main with an Eagle cast crank, H-beam rods and KB Hyperutectic FT's. I have factory 441 heads with 2.02/1.60 valves.
I'd like to hear what other peoples experiences have been, both good and bad when doing a build like this. I've been researching forums and have a good idea what I'd like to do, but always like to hear what others have been doing. Ideally Im looking to build a decent 600hp engine that has good street manners for the occasional trip to cruise nights or maybe once or twice a year to the track. Long distance cruises across my state are not out of the question either at times, maybe two times a year.
Here are some questions I have:
Should I ditch the current block and go with one that maybe only needs .030 overbore, or am I safe running it at .060? I have been contemplating using a newer vortec block for a roller cam setup anyway.
To get to the 600 HP mark, am I better off with a P1SC or D1SC? Will the D1 work less to achieve the same results and make less heat?
I currently have a BG 825 Demon carb-Worthwhile to switch it to a blow-thru version or just buck up and purchase one?
Thanks for any help!! Jason
Old 11-15-2011, 12:31 PM
Madmax305's Avatar
A few years back, I had a Procharger D1sc, on my 03 Mach-1 pushing about 15lbs of boost on 91 octane. I am now running a Kenne-Bell 2.8 twin screw supercharger with 20lbs of boost. The D1 is a great supercharger, do not waste your time on the P1, (too small). The D1 is good to about 20lbs of boost. You will want your CR around 9-1. Just remember when it comes to Superchargers, HEAT AND DETENATION ARE YOUR WORST ENEMIES.
Make sure you run an intercooler, or some type of Methanol injection to keep the boost temps down, or you will melt pistons. You will have to run a rich AF ratio when you are in boost or you will detonate which is bad for the internals. The D1 in a centrifical SC, you will have a nice linear pull on the engine when you get everything dialed in. This type of SC is not too bad on internals, because it starts to make HP and TQ in the higher RPM range. If you can, it is best to have it Dyno-tuned, with a tuner who knows what he is doing. You will enjoy the this supercharger, just don't go to radical on the boost and everything will be fine. Nothing stealth about the D1, it sounds like a 747 jet at idle.....HEHE.
Paint experts,please step inside. Z51JEFF Body - Exterior 15 11-20-2010 09:40 PM
Good GM Transmission Link for step-by-step instructions d&c repairs it all Transmission - Rearend 0 09-30-2008 03:12 PM
illustrated step-by-step wing window replacement bullheimer Body - Exterior 0 04-07-2008 11:13 PM
392 hemi guys, please step inside atotalnincompoop Hotrodding Basics 5 02-10-2008 12:00 PM
Crazy idea for a street rod - step inside the mind of a mad man... toddshotrods Hotrodders' Lounge 101 01-04-2008 05:48 PM
