who has Milodon main caps? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2006, 12:37 AM
malibu68's Avatar
Ive seen milodon main caps used on tv but I was wondering what other people had thought. i know they have a unique design that is suposidly stronger, do you drill the angled wholes yourself?
just looking for some feedback and if they are worth it
Old 07-15-2006, 08:22 AM
This is a mod we do for race motors using the Milodon or more typically the Oliver caps. It is my no means an at home machining process as what we do is mock the caps up bore the holes on the Bridgeport and align bore/hone the journals to size.
You can't just install the caps, drill and tap the holes and install the crank.
Are they worth it? On racing motors where we have to use stock blocks and are run at 7000 RPM for extended periods of time, I think so. Better than loosing a crank out the oil pan.
Depending on your buildup a much cheaper alternative may be to simply upgrade to ARP bolts. Assuming the current caps are tight and show no signs of chatter or heat.
Old 07-15-2006, 11:29 AM
malibu68's Avatar
ok the only reason i ask is that i have a 350 with a 671 goin on it and 2 bolt mains, i was goin to have it machined at a proper shop but it seems to mislead in their adds. Is there a better way of streghening my bottom end? i am scared of those 2 bolt mains under heavy load
400ci SBC missing 4-bolt main caps? wayfast77 Engine 6 12-05-2005 09:47 AM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 10:14 AM
406 with splayed main caps, maybe a problem? machinist please help. 406 ss monte Engine 11 10-30-2004 10:18 PM
bbc,sbc main caps torque and thrsut bearing abe Engine 3 05-29-2004 07:23 PM
Main caps... questions blndweasel Engine 12 05-18-2004 06:45 AM
