They didn't just dream up these rules. Much of them were seen to be needed over years of DEATHS on the track. Yes it may be a bit overkill, especially on a street/strip car that isn't running 9's. But on the dedicated 9 second race car every one of those rule should be respected. They created them for a reason.
Brian |
I do imagine most folks understand that the rules are a result of an incident or for the purpose of leveling the field . Apparently the poster got whacked by tech cause he had this rubber line, so he grips ..no big deal.
If I hauled my car to the track and over looked something like this and took a hit . I would gripe, I went to race.. chill out. I am sure he is racing he understands the rule and would be happy to comply. He did not sound like he did not respect the rule to me ..... |
Brian |
That dose work if you had the part, guess he may not have ..
We here have an issue with the local tech inspectors as they do not use a checklist when teching a car..so you go and pay your entry fee and then the tech finds something to fix you go home and fix it go back pay another entry fee and find out there is something else they don't like..Arrrrgh Grrrrrr..
Back in the day we had a checklist to follow when inspecting a car and followed that..if we found issues the owner got a copy so he knew what needed to be addressed and when he did he got to run.. Bunch of shadetree guys teching at our local track as far as I can see...BTW I bet the OP is trying to run at our local track.. Sam
Brian |
Well Mark Niver died recently at our local track because some fool failed to check the attachment of the chutes to his rail..So just maybe some "H" needs to be raised over this issue..
Sam
I think it's a good rule..I have watch a few burn to the ground at the end of the track..
And the look on the racer's face wasn't good.. I seen pictures of a street rod.. (Fiber glass car) sitting on side of the road.. burnt to the ground too.. I hate to see people cut corners on safety.. And fuel and brakes is at the top of the list, In my book.. And yes 99.9% of the rules are made because of Deaths.. Sad to say !!!
And a lot of rules are there to MAKE you do things right like the no covering of welds.
Like all rules, they don't stop the people hell bent on doing something stupid. They found that the 12 inch rule was fine because that allows you to have hose at each end of a steel line that gets the job done. If there was no rule there would be the guy with rubber hose running back to the tank 12 feet long. Do they make it 13 inchs, would that make things better? 12 inches is enough, so they set it at that. Brian |
Only rule I have a problem with is the 2 year expiration of racing seat belts, but factory originals are good even if 40 years old?? Makes no sense. |
Back in the seventies when I was a tech director we had a list.. It was called NHRA RULE BOOK..
!2" of unsupported line rule was in there then. I had to refuse several cars because of it. There are guys that think nothing of running rubber (yes, and the JUNK red tint and clear) lines all over the engine compartment.. Then there the guys that try to pass BEVERAGE tubing off as braided gas line.. Not on my watch!!! Rules aer there for your safety.. |
| Recent Hotrodders' Lounge posts with photos |
| Camaro fuel line issue, please help!! | 80's rule! | Hotrodding Basics | 13 | 07-16-2009 06:49 AM |
| F150 issues | ALL FORD | Transmission - Rearend | 27 | 06-30-2009 04:28 PM |
| Fordlandia | Jon | Hotrodders' Lounge | 2 | 11-15-2006 07:08 PM |
| Body Line | Man586 | Body - Exterior | 6 | 08-20-2004 08:24 AM |
| Aluminum fuel line vs. rubber near engine | McDeuce | Engine | 1 | 02-16-2004 06:39 PM |
