Who makes the best oil filter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 05:39 PM
So many oil filters on the market anywhere from $3.99 to $12.00 Which one do most of you use,and why?
Old 08-16-2011, 05:48 PM
cool rockin daddy's Avatar
Do a forum search at the bottom of the page. Many discussions and a couple of papers on the subject.
Old 08-16-2011, 10:12 PM
WIX all the way around here.
Very high quality and reasonably priced.
Old 08-16-2011, 10:13 PM
ScojoDak's Avatar
Mopar for life!
Wix hands down!
Old 08-16-2011, 10:31 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Do you need a third vote !!
Old 08-16-2011, 10:33 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
That is like asking who makes the best motor oil.
BTW, another vote for wix.
Old 08-16-2011, 11:04 PM
I use k&n or mobile 1 filters and castrol syntec or mobile one synthetic.
Old 08-17-2011, 06:14 AM
Banned
Wix or Napa Gold (reboxed wix). If you can't find that then go with AC Delco.
Old 08-17-2011, 06:41 AM
T-bucket23's Avatar
Wiki Edits: 26
OEM's are usually high quality (WIX makes a lot of them)
Chet
Old 08-17-2011, 06:43 AM
Looks like Wix or Napa, been using Purolator maybe I'll switch
Thanks!!!
Old 08-19-2011, 04:28 AM
FastOrange's Avatar
AC Delco is junk according to this study, the winner believe it or not was a Fram xtended guard.
http://www.gmtruckcentral.com/articl...lterstudy.html
Old 08-19-2011, 05:02 AM
Irelands child's Avatar
For my Fords, Motorcraft, Purolator or WIX and not necessarily in that order tho Motorcraft has served well as an OEM part. Also try to use Motorcraft for fuel and air as well.
Irelands child
Old 08-19-2011, 05:28 AM
I use purolator, never had any trouble, if I run synthetic I use a Mobil K@N or Bosch Extended service.
I had heard that the tighter restrictions of high end filters in some applications can cut down on oil pressure. This may be a gimmick because nearly all filters have a bypass so I dunno.
I like WIX but few places in Lynchburg carry them so I stock Napa Filters at my garage and prefer using them or Purolator.
Now just to fuel the fire I prefer Castrol Oil but I do have a bit of money in BP>
Old 08-19-2011, 07:27 AM
No by-pass
Chevrolet oil filters do not have a by-pass valve if a by-pass valve is built into the engine. According to WIX, if the engine block has a by-pass valve, their filters do not have one. Don't confuse a by-pass valve with a anti-drain back valve. GM filters are mounted vertically and don't need a drain-back valve but all the GM filters have one anyway. The stock Chevrolet SB & BB engines have a by-pass valve built in part of the engine block oil gallery located above oil filter and is designed to start opening at 8 PSI and is completely open at 15 PSI "differential" pressure. Differential pressure: If the oil pressure entering the filter from the oil pump is 50 PSI and the pressure leaving the filter is 40 PSI the by-pass valve will open and pass 10 PSI "differential" pressure and is unfiltered oil.
I use a AC Delco Ultraguard Gold UPF52 8 micron filter or a WIX 51036 21 micron filter but I change the WIX filter more often ($4.58 each). I change the WIX filter twice between 6500 - 7000 mile oil changes. My Chevrolet 4.3L V6 engine has a 21 PSI by-pass valve in the block and a 21 PSI by-pass valve in the remote filter adapter on the fender serving as a back up. The AC Delco UPF52 has a lower flow rate than a WIX filter due to the denser high filtration media so I use a WIX to prevent the by-pass from opening. GM installed two 21 PSI by-pass valves in the oil system due to the resistance to flow caused by the oil cooler-remote oil filter and 8 feet of oil lines.
GM planned to discontinue the AC Delco Ultraguard Gold UPF-52 (GM 25322836) along with all the other Ultraguard filters due to lack of demand by the general public due to the cost, MSRP $21.00 each. GM decided to lower the price to MSRP $16.76 each and extend production of the UPF-52 because of the number of protests from Corvette and Cadillac CTS-VR owners. I have collected forty-five AC Delco Ultraguard Gold UPF-52 oil filters because they are only sold at selected retailers and may be discontinued at any time. GM Parts Direct sells UPF-52 oil filters discounted for $8.55 each but minimum shipping is $12.95. The AC Delco Ultraguard Gold UPF-52 is just a little better than a Mobil 1 M1-201 which is a 10 micron fllter.
Old 08-19-2011, 07:33 AM
Banned
seems like a very subjective (ie useless) test. And even at that most would agree the Mobil 1 filter beats the Fram EXGuard on their test. Price is NOT a factor of ability but a lack of filter media leading to poor flow (which Fram is known for) is. Also, biggest complaints against Fram that I have seen is a bursting filter and the bypass sticking open or shut- the bypass wasn't even tested.
Ask any professional seasoned engine builder if they'd use a Fram...
Who makes the best Kit Car? Pirate2112 Hotrodders' Lounge 15 12-23-2009 03:37 PM
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 06:24 PM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 07:31 PM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 10:44 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 01:56 AM
