who needs those HIGH $$$ steering joints, not me! ! ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2007, 05:30 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
MORE PIC's - - who needs those HIGH $$$ steering joints, not me! ! !
as everyone knows i'm one cheap SOB when it come to building my rides, always was & always will be. with then help of family, friends & great deals i have been able to keep my cost really down on Large Marge && here's just another example of what a cheap SOB i am. i love to go to the boneyards to find stuff to help cut the cost on everything & here's one of my good finds.
over the years i have collected different GM FWD & Chevy Astro Van steering joints all using the Double D shafts & tubes.
This is off a fullsize FWD GM car & this 1/2 is attached on the column
not a clear pic but this end will except a double D Tube
This Double D Tube will except a double D shaft.
This is what one looks like before you take it apart
This is 1/2 of the Astro Van steering shaft.
These are easily found on I believe every GM trucks & RWD cars. You'll get about 6inches of Double "D" tube & about 12inches of shaft(LMAO)
This is the lowwer part of a Chevy Astro Van steering joint && the BIGG plus is that it has a vibration damper built in. I also drill a spot in the double D shaft so I could use a set screw & jam nut to hold everything in place.
I'm using 1/2 FWD GM & 1/2 Chevy Astro Van steering joints to make up the steering joint going through the firewall. The piece of pipe you see coming out of the firewall is an exhaust pipe reducer. I cut the end of a steering column off w/the bearing & welded the piece of tubing(that holds the bearing) into the exhaust reducer. I did it for extra support & to help seal the cab from exhaust fumes.
Using a FWD steering column the male part of the steering joint going through an Exhaust pipe reducer.
This shows the complete set up. All that needs to be done is to weld or bolt the piece of pipe that holds the Hiem Joint to the frame. The reason for the hiem joint is the steering column bearing that I used on the outside of the firewall to help support everything isn't a snug fit & this is one place OVERKILL is a good idea.
if for some reason the pics dont show up look on THIS PAGE it the last page in my Large Marge pics on Webshots
Old 01-31-2007, 05:35 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Looking good! Thanks for the info....now we can all save some money.
Old 01-31-2007, 06:23 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
TooMany2count -- can I add this to the wiki? I can do all the typing, but I need your permission to use the webshots photos.
Old 01-31-2007, 06:35 PM
Wiki Edits: 5
Jon look at it all & u can use anything u want from my webshot pages that u deem useable, it would be my pleasure to be able to help save folks some $$$$$$$$ & give them ideas on how & what to do. ...joe
Old 01-31-2007, 06:45 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
That is not to bad at all! I would trust that more than the rag joint on my camaro!
Old 01-31-2007, 08:10 PM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
Thanks TooMany2count -- here's the article: Steering shaft assemblies from junkyard parts.
Please look it over to make sure I got it right. You (or anyone else) can feel free to edit or add to it at any time.
I'm trying to get us in "the wiki habit", and hopefully this is a good chance for people to see how easy it is to turn a good post into a permanent article that we can add to or update whenever we want.
Old 01-31-2007, 09:18 PM
Wiki Edits: 5
looks fine to me, BUT i will try to get a couple of better pic's of the blurry ones. i will also take it all apart & get a complete break down pic of everything along w/showing how to make the piece going through the fire wall...joe
Old 01-31-2007, 09:33 PM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
OK -- great, thanks again. I tried to do an "edge sharpening" on the one blurry pic, but there's only so much you can do with that.
Let me know if you need a hand with any of the wiki functions, uploading, etc.
Old 01-31-2007, 09:43 PM
Wiki Edits: 5
will do.................
i also wonder how many readers realize that i'm using a '93 Buick Park Ave FWD steering column w/a stock cable shifter w/this set up????? my webshot page on Large Marge shows it all in the last 2-3 pages of the album...joe
Old 01-31-2007, 10:10 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
TooMany2count and Jon - Thanks for the info!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-01-2007, 07:54 PM
Wiki Edits: 5
made corrections brought to my attention
here's a couple more pic's of everything...joe
Frome left to right.. 1st steering joint goes to the steering box, this is the lowwer half of a Chevy Astro Van & has the same splines as the S10 steering box I'm using. 2nd is a piece of double D tubing which connects the 1st steering joint to a piece of double D shaft w/a piece of double D tube attached to it which goes to a steering joint. As you can tell everything has been drilled & tapped for set screws & lock nuts for safety.
As you can see both the Double D shaft & tube has be drilled & tapped for set screws & jam nuts for safety. Personally I believe this is a must.
From left to right. 1st is the double D shaft & tube w/the tube having a set screw & jam nut. 2nd is the outer steering joint w/a lowwer steering column bearing attached which goes into the tube that is coming out of the firewall to help hold the hold everything(EXTRA SAFETY) You can't see it but it also has a set screw & nut on the double D tube. Also I'm adding a set screw & jam nut to the opposite side of the locking bolt for added safety. 3rd is the inner steering joint that attaches to the column on the inside of the cab. 4th Last but not least is the bottom of the 93 Buick Park Ave steering column that I'm using.
This is how I mounted the Hiem Joint to the frame. I simply took a piece of pipe & mounted the Hiem Joint to it by welding a jam nut to the pipe & then had a friend chuck it in his lathe & clean up my weld. Then I took some angle iron & made a mount to bolt it to the frame.
As you can see everything is bolted together & looks good. It may look like the steering shaft is touching the exhaust manifold but really it's about an inch away from it. The upper joint is almost 2 inches away from the manifolds.
Be sure that you have some space between your Hiem Joint & any tubing you are using. You need this for body & frame flex so the shaft can side with in the Hiem Joint if it needs to.
As you can see the steering is complete w/a Hiem Joint to secure everything along w/the set screws & lock nuts for added safety............ PLEASE, PLEASE, PLEASEEEEE be sure to check any used parts that you do use on your own projects for wear & defects along w/adding set screws & jam nuts w/lock tight for that added safety. REMEMBER that this is one place that SAFETY OVERKILL is a good thing.
i dont want someone to hurt themselves & if there is ANY DOUBT in their minds whether or not a USED part is still good enough to use or they don't have the knowledge how to check for wear/defects then by all means buy a new parts
Old 02-22-2007, 03:43 PM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
OK, I've updated the article, and added the safety information at the top: http://crankshaftcoalition.com/wiki/...junkyard_parts
Feel free to edit, add to, or update it at any time.
Old 02-28-2007, 02:52 AM
staleg's Avatar
Last journal entry: Hand brake
I'm going to use a steering column from a Chevy Astro. I have a complete column included joints, pipes and shaft all the way down to the stering box.
It will be used on a 34 Ford with a manual Mustang II steering rack. The steering pin dimension on the rack is 9/16-26 splines.
Can any of you help me with what I need in addition to my Astro parts?
Will the Astro/S10 steering joint fit on my Mustang II manual rack?
On my setup I will probably be needing 3 u joints total: One on the rack, on in the lower end of the column and one between.
Then I must of course have a support somewhere near the u joint in the middle.
Old 03-01-2007, 06:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
What would be a good way to make this into a slip joint for a collapsable column effect in case of a crash?
I'd like to see 8" of collapse.
My car is a rear steer with a solid shaft and rag joint.
Old 03-02-2007, 02:41 AM
staleg's Avatar
Isn't the Astro column collapsable already?
And with a total of 3 u joints between the rack and column It would probably collaps pretty much anyway?
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
56 Ford Victoria pwr. steering options? murrsue Suspension - Brakes - Steering 18 02-05-2006 02:10 PM
Steering Question smoke_eater Suspension - Brakes - Steering 4 12-04-2005 09:41 AM
chevy high pressure power steering hose 454me Suspension - Brakes - Steering 4 08-10-2005 08:01 PM
Steering box/Coupler (rag joint) Questions RObs71Nova Suspension - Brakes - Steering 1 10-26-2004 11:34 PM
