Who sells Dropped Center Links? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2006, 03:27 PM
Hello, I'm new to this board, and I'm from Connecticut. I have a 1970 chevelle SS clone. The oil pan on my 632 C.I. engine had to be made so deep to clear the connecting rod caps because of the massive 4.75" stroke, that the steering linkage center Link ( aka "Drag Link") won't clear the oil pan.
So before I go ahead and heat this thing up with a torch and try to bend it enough to put more of a drop in it, can anyone here tell me of any place that offers dropped center links for GM A-body cars ??? It looks like I'll likely need an additional 1.5" of drop in the center Link. I already had to cut the crossmember to make room for this monster, and I now have the engine installed. below are some pics...
ID:	14737   Click image for larger version
ID:	14738   Click image for larger version
ID:	14739   Click image for larger version
ID:	14740   Click image for larger version
Old 09-09-2006, 03:31 PM
...here's more....
Name:	massive block.jpg
ID:	14742   Click image for larger version
Name:	oil pan sideshot.jpg
ID:	14743   Click image for larger version
Old 09-09-2006, 08:12 PM
poncho62's Avatar
Wiki Edits: 5
I would be more inclined to go to a different pitman arm and relocate the idler arm................I am no steering expert, so I may get shot down here.
Old 09-09-2006, 10:07 PM
Naw, I won't shoot you down so to speak, but I must point out that although I appreciate your effort to be of help to me, I Had already previously found and ordered a pitman arm with more of a drop, which is for a Jeep Wrangler, and i had also planned on relocating the mounting holes in the frame for the idler arm just as you've explained.
But I learned from others that the problem with that is that I would be changing the angle of the tie rods, and they would no longer be parallel to the lower control arms, which would create a lot of bump steer according to what I'm being told. Having the steering move from left to right while negotiating every bump in the road doesn't sound fun to me, so that would be out. And having more of a drop in the center link instead would be better since that wouldn't change the angle of the tie rods.
Old 09-10-2006, 12:09 PM
Originally Posted by BillyGman
But I learned from others that the problem with that is that I would be changing the angle of the tie rods...which would create a lot of bump steer...
This is true.
Do your tie rods go into the steering arm on the knuckle from the top or the bottom? If they go in from the top you could move them to the bottom. You would have to weld up part of the hole and use a tapered reamer (most likely 1-1/2 inch taper per foot) to ream the other side. I have also known people that have had tapered inserts made to fill the existing hole and either brazed or loc-tited them in before reaming from the other side.
Also I think Global West ( www.globalwest.net ) uses a custom center link for their 12" disc conversions...but it might have been another car and their website is being updated right now so I can't double check for you. You might try giving them a call.
Old 09-10-2006, 01:35 PM
Originally Posted by Triaged
This is true.
Maybe I'll give them a call, but I just looked in their new catalog lastnight and I didn't find any dropped center links. And the tie rods on my car unfortunately attach to the bottom of the steering knuckle. But thanks for brainstorming for me pal.
Old 09-10-2006, 02:13 PM
You have bolt on steering arms right? If so these would lower the outer tie rod end. You would have to call them to find out how much.
http://www.stockcarproducts.com/susp20.htm
Old 09-10-2006, 04:47 PM
Thankyou!! I'll give them a call.....hopefully all there stuff isn't just for Camaros, Mustangs & Novas. That's usually the case with many places...
Metalcraft Tools Skill Center, Online Video Training HotRodin77 Hotrodders' Lounge 3 07-13-2006 07:19 AM
center section measurement??? rlb Transmission - Rearend 2 01-30-2006 07:34 PM
Painless Harness and Fusible links cucumber1949 Electrical 6 10-11-2005 06:12 PM
Instant Center Location Of 4link BillyShope Suspension - Brakes - Steering 4 08-12-2004 06:27 PM
