Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Who sells terminals?
Old 05-07-2006, 10:41 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
You can buy a Box (case) of ring terminals At ACE HARDWARE for about $8 bucks..(insulated or un~insulated) The Case is about 500 terminals..Good for harness repair.(All three sizes..Red, Blue and Yellow)
If you go un~insulated get some Heat-shrink tubing to slide over the terminal "Barrel".
If at all possible, the best procedure is , Solder & Crimp... Tin the wire, tin the terminal, then join them together in the terminal, and apply heat and solder until it flows smooth and shiny..then crimp..That installation will last forever..never give you a problem.
Doc
