Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Who sells terminals?
Old 05-12-2006, 02:39 PM
zipfactor's Avatar
zipfactor zipfactor is offline
Last journal entry: Just starting
i went to my local parts house (its a bumper to bumper chain). But the cost is 4.50 a box for 10 terminals. to get the spade type terminal (male end) out of the housing, you have to take a pair of needle noise pliers and pinch the sides in from the top. While you are doing that, pull the wire from the other end a little bit, and it should slide right out. Most likely there is a lot of tar and nasty stuff in there to protect the terminals. hope that helps.
