Who sells a undrilled Chevy Flywheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 09:15 PM
looking for a blank 168 tooth neutral balance sbc flywheel around 34 lbs that has not been drilled for crankshaft bolts.
Are they even offered in this day of too many lawyer/lawsuits
Anyone know of one available?
thanks
Old 01-18-2010, 11:09 PM
4 Jaw Chuck's Avatar
http://www.google.ca/search?hl=en&sa...meta=&aq=f&oq=
Outlawed tunes from outlawed pipes
Old 01-19-2010, 04:37 AM
bondo's Avatar
Ayuh,.... Donno about anybodyelse,... But,...
I'd love to know Why you need an undrilled flywheel...
Old 01-19-2010, 10:50 AM
My project is a little strange but something I have been on and off of for a few years.
Mercedes OM617 5 cylinder diesel mated to a sbc chev manual trans.
There are adapters out there for $1k but I am doing this from a different approach and want to re drill a blank neutral balanced Flywheel and make a thin adapter between the bell housing and block.
The Mercedes crank has twelve 3/8" bolts and the Chevy has six 7/16 bolts.
I was going to re drill a standard flywheel but would like to start with a blank
steel flywheel. ( see first pic)
*the links above were mostly alum flywheels.. looking for heaviers cast steel
flywheel.
opinions appreciated
The last pic is the desired result... Land Cruiser /Mercedes Motor.
ID:	43309   Click image for larger version
Old 01-19-2010, 12:50 PM
Why can't you use a Mercedes flywheel and pressure plate and a Chevy disc and mod or different throw out and pilot bearings?
Or, drill the Mercedes flywheel for a different pressure plate.
We usually learn more as we go.
You might make an crank adaptor. Six counteersunk hole to bolt to the crank and six studs to accept the Chevy flywheel. This would mean you might have to make an adaptor to move the trans back or maybe not, as the clutch may still fit in the bell housing with a shorter or modified throw out bearing. A longer pilot bearing amy aslo be needed.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
350 Chevy starter pinion to flywheel clearance Bonehead4x4 Electrical 8 03-28-2009 03:49 PM
Flywheel for 89 Chevy 350? shad88 Transmission - Rearend 4 05-01-2007 07:31 AM
67 Chevy Flywheel Cover jbersk Transmission - Rearend 1 05-31-2006 10:20 PM
Additional 50hp from heads, or 200+lbs off the nose from a LW front suspension clip? NLang General Rodding Tech 29 12-15-2005 02:31 PM
