Who is the sewing machine mechanic here? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2013, 12:37 AM
UJSLOST's Avatar
I bought some new presser feet which are suppose to be the correct ones. And now I got all sorts of issues!!!!! Singer 151w2
Old 12-31-2013, 09:07 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You may have a problem finding parts for your machine because it is so old, at least 90 years old. This machine was set up originally to sew collars onto clothing. It only has 5 3/4" of space between the needle and the upright part of the machine. This is not probably a machine that will do very well on auto interiors, because most machines have 10 1/2" of space between the needle and the upright. The only Singer part numbers I can find for your machine's foot is 208597, and 208598, and they are not a presser foot. I don't know if they ever made a standard presser foot or a welt foot for this machine. Here's the part list for the machine: http://parts.singerco.com/IPpartCharts/151W2.pdf I thought you had a 111W151, which would have been fine, not a 151W2.
Old 12-31-2013, 11:28 PM
UJSLOST's Avatar
Thanks Dan for checking into this. After workin on it for hours and taking the presser bar assembly apart I think somehow I got the timing of the presser foot and the vibrator foot off. Presser foot comes up when it should, but vibrator foot lever lifts as needle lifts. After reading the instructions in that link about 500 times, it looks like lowering the depth of the presser foot makes the vibrator foot raise higher. Which makes since. Because I can slightly raise the presser bar (which essentially lets the presser foot have further travel downward) and the vibrator foot will go up and down as it should with the needle movement. I boogered up the screw in the back that locks the adjustment on the presser bar (flat head screw). So Im gonna see if I can find something compatible locally tomorrow.
I have to check my part numbers against 111w151 part numbers a lot just to find parts. Alot of 111w parts do interchange, and alot do not. I will update tomorrow and let you know how it turns out. Otherwise, Im gonna sell it to the local sewing shop and look for something else. Preferably with reverse.
Old 01-01-2014, 06:45 PM
UJSLOST's Avatar
Dan
After the slight adjustment in the presser foot she is now sewing like a champ again.
I'm Becoming a Bit of A Sewing Machine Mechanic Coodeville Interior 1 08-26-2012 08:07 PM
sewing machine mechanic varo fereti Introduce Yourself 1 01-19-2012 11:34 AM
new (to me) sewing machine mmiller Interior 21 06-08-2011 02:53 PM
Are The Days of The Sewing Machine Mechanic Numbered? Coodeville Interior 6 08-31-2010 07:00 PM
Need help with that sewing machine? KennyG64 Introduce Yourself 2 08-28-2006 09:16 AM
