who uses peunut heads on his 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 03:50 PM
roy383ci's Avatar
hi
i can get a 454 block with peanut heads on them motor needs rebuild.want
to keep the heads (budget)
after reading all the story's on how allot of people say the peanut heads suck
i want to hear some from people ho have them on there 454,and how many power they can make.
this is my plan (not a daily driver)
454 block
balancing the rods and pistons 9.0:1 comp dome pistons
porting the peanut heads manley valves under cut
nice cam give me a Little help here (not a bbc expert)
750 edel carb
headers dual exhaust
full roller rockers
msd6a
aftermarket intake port match
whats the power potential for this 454
thanks
Old 09-22-2006, 10:06 PM
Bumpstick's Avatar
Hammer and a torch
Will work great in a 4WD... But in a steet car it will suck but can be useable none the less, just very RPM limited...
If your going that far why not find a set of large ovals...? They are not that expensive and with the aftermarket valves you mentioned they would really give you neck pain... (the good kind)
Old 09-23-2006, 01:47 AM
roy383ci's Avatar
well i know bigger ovals flow better (are all the ovals out fitted with small valves)
well i live in the Netherlands and they ask allot more money for those heads
over hear so i thought use what u got
the small parts i can import my self
Old 09-23-2006, 09:41 AM
Bumpstick's Avatar
Hammer and a torch
Yes all of the large and small ovals come with the smaller 2.07 intakes and 1.70 exhaust valves... Seeing how your location does limit what you can aquire then they may be a good app for you...?
Hey figure out how to get them shipped and I have 4 sets of either 049`s or 781`s I would let go for $150 US per set (bare heads)...
Old 09-23-2006, 04:16 PM
roy383ci's Avatar
bumpstick in what state are those heads
do they need new guides and seats .
i like the price for a set
and witch are better the 049 or the 781 and whats the difference.
thanks.
Old 09-23-2006, 05:25 PM
Bumpstick's Avatar
Hammer and a torch
Hehehe... State...? Why Texas of course...
1 set of 049`s are hot tanked and clean the other pair are dirty... The 781`s are hot tanked as well but are slightly different, one is a 781X the other is just a 781 but look the same... The other set I have is a set of semi-closed chamber heads that I`m saving for another project... All need guides but seats are all good...
049 or 781 might as well say twins... The came on the same HP engines over various years...
Old 09-24-2006, 02:26 PM
roy383ci's Avatar
well i checked the shipping price for those heads
thats more than the set would cost and i have to pay 20%tax here so
sorry but thanks for the offer
is there any one who uses them they wouldend seem to bad
i found a combo on the net at http://www.camaros.net/racing/BBCombo.html
Street combination:
Hiperf 454 4bolt block (std boring)
"Peanut" oval port heads (mild port work)
2.19/1.725 Manley raceflow valves + multiangle valve seats (30,45,60 deg.)
CompCams magnum rocker arms
stock 8.75 to 1 cast pistons
stock rods
stock cast crank
Edelbrock torker intake
552/555 230/236 @.050 (CompCams XE274H)
Holley 850DB carb
FlowTech 1-7/8 headers
Dyno result with 3-inch exhaust & pumpgas: 526ft/lbs@3500rpm, 468hp@5100rpm (over 500ft/lbs torque from 2800rpm to 4800 rpm!)
Old 09-24-2006, 06:03 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
At 9.0:1 and a "healthy" cam, you'll definitely notice that the peanuts suck. On a truck with 7.8:1 and a 1975 cam, they'll be fine to 4400 rpms
I agree... hard to beat the 049s or 781s. Very little difference in my opinion at this level.
Old 09-25-2006, 02:56 PM
Duke of Cruel's Avatar
Car nerd
Originally Posted by roy383ci
hi
454 block
750 edel carb
full roller rockers
msd6a
thanks
Peanuts is the things there is in turds, right?
Buy a decent set of used heads, and you will be much better off. Proberbly cheaper then overhaul the turd heads too.
Good luck with your project.
DoC
454 BBC heads by FoMoCo?? WakBordr7387 Engine 9 06-13-2006 10:30 PM
cheap 454 with peanut heads Haulin327 Engine 6 05-27-2006 11:06 PM
Can I just “slap” 454 heads onto a 502? Bayley Engine 2 05-15-2006 07:12 PM
66 heads on 74 454? smac Engine 4 02-15-2006 04:55 AM
454 Heads Junk or keepers? roys63 Engine 3 11-12-2002 06:03 PM
