WHOA CANT STOP - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2003, 04:07 PM
Post WHOA CANT STOP
I HAVE A 78 TRANS AM DISC FRONT DRUM REAR WHEN I HIT THE BRAKES KIND OF HARD THE REAR WHEEL DRIVERS
SIDE WHEEL LOCKS UP AND IT DOESNT FEEL LIKE THE FRONT BRAKES ARE GRABBING HARD
Old 02-08-2003, 04:18 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
just an idea, but have you checked the adjustment on your right-side rear shoes? maybe there's too much slack on that cylinder, causing only the driver's side to lock, and causing less pressure at the front of the system.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 02-08-2003, 04:47 PM
5.0Towncar's Avatar
Post
Yes I had that problem......When my front right brake line was split.Is your master cylinder full, in other words are you leaking out of a line. Steve
Old 02-08-2003, 04:57 PM
Post
NO LEAKS MASTER CYL FULL BUT PEDAL IS KIND OF HARD TO PUSH
Old 02-08-2003, 04:59 PM
5.0Towncar's Avatar
Post
Well........Hmmmmm.........Been bled recently??? . I don't know I just had the same thing happen to me. Steve
Old 02-09-2003, 10:49 AM
Seon's Avatar
Post
[quote]Originally posted by MIKE T:
<strong>NO LEAKS MASTER CYL FULL BUT PEDAL IS KIND OF HARD TO PUSH</strong><hr></blockquote>
Check your power brake booster. You master cylinger may be leaking in the booster.
