Wht's Thumpr
What's your guys opinion on comp thumpr cams? I'm looking to use one in my combo: 781 heads-big valves,dual intake,holley 800 sr.bo., 10.5-1 compression,hooker headers,forged pistons.
Looked at biggest hydraulic flat but is only 520/507 lift. Maybe small for me. Next is roller. SUPER expensive but they have 570/544 lift and 558/546 lifts. Just want good power and awesome sound for cheapest. how much power would these flat tappet vs. roller ones? |
In addition to Eric's observations, the Thumper line appears to be relatively over priced. I'm no great engine expert but my capsule review of the Thumper would be, Big sound...small hat. And the company basically admits that in their advertising. The purpose of this cam was always to produce the "effect" of a big cam in terms of sound. It was never intended as a major player in the power department. A close inspection of grind specs will reveal many other cams which will produce more power for fewer bucks.
But then if all you are after is the sound and a bit of HP...the Thumper would be a good alternative.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
What THEY said........You need to realize its the LSA that makes the idle you want....in addition to the duration. Different cam comp. have different philosphies on how to make power. Isky have alway ground most of there cams with a tight LSA(small=tight) 108*.Lunati too I think. They have the rumpity-rump sound most guys like in a street rod. Other comp. like more LSA to get better vacuum(to run brakes and stuff) and spread the RPM range out abit. Different ideas to make power.
You can get a custom ground cam with THEIR expertise ground in for less than the Thmpr cam. AND make alot more power....customized for your engine combination. IMO 6sally6 |
I don`t see the point in even making a cam like that when you can take a basic .224 duration cam and play with the idle and rocker adjustments to make it lope.
Awwww DV...you're tooo young to think like MY dad! Sure you can"jerk a plug wire off" and richen up the carb and all that stuff,but........you know you break out in a big grin when somebody fires up a big-block...full-tilt...race-only...engine in their weekend play-purty at the local car show! Totally useless for a dailey driver but still.....THAT GUY always has a couple of "pals" hanging around and a small gang of old men (like me) loitering near by waiting to hear that really "bad'un" fire up. Or do you really get into a nice Mercedes with their powerful engine whisper off down the road?! Your a "good ole boy from Alabama"....I know you like them rad sounding machines!! 6sally6 |
Sure, but I never had a problem with making a cam lope that had some duration to it. I never fooled with big blocks, I`m a poor man, poor man`s engine is a small block. I run roller cam 350`s and when you got small cubes, it`s easy to get it to lope. .224 duration @.050 in a 350, it`ll lope, even a comp cams .218 will. However years ago when we stuffed a .234 cam in a 400 small block it idled smooth. Of course we have to add in what kind of overlap it has, the exhaust system and other odds and ends. I`m by no means "old school" as far as that goes, I just never had much problem getting one to lope.
| thumpr with stock heads? | phanline6.6 | Engine | 17 | 01-02-2010 07:56 PM |
| How about a thumpr | sapsz28 | Engine | 7 | 11-26-2009 01:46 AM |
| Blue Racer vs. Thumpr | automods | Engine | 6 | 01-31-2009 03:08 PM |
| Comp Thumpr Cams - Any good???? | Eagle1 | Engine | 5 | 05-19-2008 08:06 AM |
| Comp Cams Thumpr Cam | Geradmg | Hotrodders' Lounge | 5 | 03-28-2008 05:12 AM |
