Why 37-48 Ford Spindles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2006, 11:18 AM
32 Ford Model B
Last journal entry: 32 Ford LittleTruck Family History Pt 10
I have a pair of what I believe to be 35-36 Ford spindles and am thinking about using them on my 32.
The obvious difference is the backing plate bolt pattern is smaller at 3" rather than the 3.75". Really, that's the only difference I see.
What makes the 37-48 spindles special? Are the steering arms different? Axle boss spacing? Camber? Strength?
Old 01-24-2006, 11:35 AM
The main reason rodders use the 37 to 48 spindles is that is what Ford had when they went to hydraulic brakes. The later stuff bolts on. Even 56 Ford F100 brakes. The 37 to 48 is also what ALL the disc brake conversions use.....for the same reason...interchangeability.
Old 01-24-2006, 12:21 PM
32 Ford Model B
I have some homemade disc brake adapters built around the smaller bolt pattern. Sounds like as long as I wanted to use those adapters, there's no reason I shouldn't use these earlier spindles?
Thanks for clearing it up. The larger bolt pattern allowed folks to use OEM hydraulic brakes. Now, all mass produced adapters use that bolt pattern, so that's the spindle everyone wants. Is that right?
Old 01-24-2006, 12:46 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The 37-48 spindles are still being produced in the aftermarket world...that is another good reason to use them as you can get replacements if a bearing goes bad and ruins the spindle or one gets broke in a wreck or something.
Can you help me identify these 32 Ford spindles? LittleTruck Suspension - Brakes - Steering 4 01-11-2006 09:21 AM
Early Ford Spindles tnoftsger Suspension - Brakes - Steering 9 02-10-2004 02:55 PM
Windshield wiper set up for 48 ford coupe DAVIDTEDDYBEAR General Rodding Tech 10 01-16-2004 12:44 PM
9" ford in 48 chev frame fat48chev Body - Exterior 7 06-30-2002 08:37 AM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
