Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - why is this car overheating
Old 07-04-2012, 09:02 PM
Project89's Avatar
Project89 Project89 is offline
Originally Posted by pacman350 View Post
a buddy of mines has a 89 camaro with a rebuilt sbc motor out if a 94 chevy truck. i dont know the specs on the motor but he can not run it with a thermostat because it will not open and he has tried 6 or 7. without a t-stat in it it still runs really worm the motor has the original serpentine belt setup. the antifreeze seems to flow out the fines in the radiator the right direction but if he installs a t-stat. we thought i they may have used the wrong water pump because it do use a reverse flow water pump but with the rad cap off it looks to be flowing in the right direction out the fines. he as a summit or griffin 2 row rad with a derale dual fan set up. the other day when the temp hit 104 down hear in georgia he couldnt drive it engine temp got up to 245 with both fans on at highway speed.
make sure the airdam is on the front of the car and not damaged.
the 3rdgeneration f-bodys are bottom feeders they pick up just about all the air that goes threw the radiator from the bottom.
if the car has ac make sure that there arent leaves packed inbetween the radiator and ac condensor
most overheating issues on the f-bodys can be cured with those 2 things.
also if he is relying on a factory gauge for the readings go buy a mechanical gauge and test it with that. the factory gauges have been known to read way off
