pressure will be the same from side to side on the front or rear regardless of length. Pressure is not affected by the distance of the line, or difference in length of lines.
distance does not change the volume of fluid required to transfer kinetic energy either, it only requires a larger volume of fluid to fill it. Loops are for absorbing the vibration and giving the hard metal line enough room to flex without breaking, it has nothing to do with brake balance or cooling. The loops in the picture are rendered less effective as the are fastened down next to the master on the firewall, there is no flexing going on here, but the technician who posted it was absolutley correct in what he said. Also he does really nice work as is evident by the photos. Last edited by latech; 03-03-2012 at 07:01 PM. |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
tech69 (08-01-2012) | ||
And by the way, I can see why someone would believe such a thing (making them equal length) but after reading the thread if you STILL believe that, I just don't know what to say. Brian |
Brian |
you are all wrong
This was Fords idea for the assmbly line in detroit to support the master cylinder for the next guy to add his parts. I know because my son in law worked for Ford
Brian |
it's for the loop de loop. it is a well known fact among the scientifical community that brake fluid digs loop de loops. |
I don't need to be right but...
I'm not sure but I was told by my dad , it added "feel" to the pedal ,or more touch control to power assisted units, to prevent lock ups. Which is unnecessary with today's anti lock brake systems. and I don't see them anymore for some reason .
Original designed
like a coil spring to support the Master cylinder for the next guy in the assembly line this was done in late 1960s by Ford if vibration is limited all well and good but that was not the principle reason for the coils I worked in a ford garage back then and I know what it was for from my son in law and Ford reps
Well I am confused as hell here. The lines would go on the master cyl last so just what would they be for? I am trying to wrap my head around this and I can't but it's been a long day.
Under what circumstances would you put the lines on the master cyl before the master cyl was bolted to the booster or firewall? I have never worked on an assembly line but I just can't grasp this. If the master cyl went on first then the lines there would be no reason for these coils to "support" anything and if the lines were in first and then the master cyl was installed, again no reason to "support" anything, explain to this old guy would you please? Brian |
Bless his heart RIP.Brian |
My dad and I both worked in a car plant.....We both said its for the vibration (and of course the loop de loop).........
Ontario Rodders |
I say loop - de -loop. shirley temple is right.
![]() I did not notice I have bourbon younger than this thread.LOL |
| new master cylinder, bleed still no brake! | customdrumfinishes | Suspension - Brakes - Steering | 11 | 11-05-2006 07:07 PM |
| Master cylinder lines | mike rash | Suspension - Brakes - Steering | 2 | 10-01-2006 09:43 PM |
| need help on master cylinder | gun70runner | Suspension - Brakes - Steering | 2 | 06-22-2006 03:29 PM |
| Master cylinder sizing, dumb question? | baddbob | Suspension - Brakes - Steering | 6 | 06-19-2005 01:02 PM |
| Master Cylinder Problem need help!!!! | 71gtx | Suspension - Brakes - Steering | 2 | 05-23-2005 11:22 PM |
