-   -   why do break lines curl coming out of the master cylinder (http://www.hotrodders.com/forum/why-do-break-lines-curl-coming-out-master-cylinder-115051.html)
excaliberprime 04-30-2007 11:31 PM
32 Attachment(s)
im just curiouse as to why the break lines curl coming out of the master cylinder i have to run new break lines tomorow and needed to know if the spiral is relavant
ricktt 05-01-2007 01:00 AM
brake line curl
They curl to absorb vibration. If you have rubber body mounts and the brake lines are attached to the frame there will be a slight movement of the frame while the master stays put.
powerrodsmike 05-01-2007 08:00 AM
That is correct, the lines make a loop to absorb movement and vibration.
Here is the last one I did. I usually wrap the tube around a piece of pipe to get the loop.
http://hotrodders.com/gallery/data/5...m/PICT2947.JPG
http://hotrodders.com/gallery/data/5...m/PICT2907.JPG
At the body to frame juncture.
http://hotrodders.com/gallery/data/5...m/PICT2938.JPG
Later, mikey
topdogger 05-01-2007 08:08 AM
Thats good to know. I just replaced the master cylinder on a 74 dodge power wagon. It was a lot easier then I thought it would be. The brake line looping was one thing I couldn't figure out though.
KULTULZ 05-01-2007 08:47 AM
http://smilies.storagebin.us/smilies/huh1.gif
I thought they were there to prevent vapor lock... :P
:evil: -MESSIN WITH SASQUATCH- :evil:
powerrodsmike 05-01-2007 09:46 AM
You bored this morning Gary?
:P
That guy on the receiving end of that "vapor stream" :pain: would have benefited immensely from a little loop in that tube.
Mikey
KULTULZ 05-01-2007 10:29 AM
1 Attachment(s)
I get a big kick out of those and the CAVEMAN series.
Did I tell you my wife did the stand-ins for SASQUATCH? :pain:
powerrodsmike 05-01-2007 10:42 AM
I'll bet you get alot of hair in your dinners.. Or does she wear a full body hair net?
and there is got to be nothing more seductive than to hear her say..." Honey can you rake my back?"
She sounds HOT! :D
Now back on topic...even a caveman can put a nice vibration loop in a brake line.
hahahahaha
mikey
joe_padavano 05-01-2007 01:54 PM
I'm not sure that's the reason (or at least, not the only reason). On GM A-body cars, the lines on cars with power brakes got the loops, but the manual brake cars just had straight lines. I've always assumed that this was to provide a little "give" so you could change the power booster without disconnecting the brake lines from the master cylinder.
ricktt 05-02-2007 12:03 AM
They did it for that too. but vibration was the primary reason.
brian0605 05-02-2007 01:05 AM
I always thought it was to help cool the brake fluid. Brian
poncho62 05-02-2007 04:30 AM
I always thought it was so the fluid could do a loop-d-loop..........That makes it happy................so it won't try to escape through a hole in the line............... :rolleyes:
kruzr 05-02-2007 05:07 AM
Very nice job on those "curls" Mike.Really adds detail. :thumbup:
I like to use the lines with coil spring, find they help me to fine tune my curls n bends(also protect the line) ,then take them off,scuff with Scotch pad then clearcoat them.Kinda keeps the lines from discoloring.
Obamasucks 03-03-2012 06:33 PM
Brake lines
They curl to keep an equal distance from the master cylinder to each wheel in the circuit . Lets just talk about the front brakes for now . Because it the same for the rear . Anyway the drivers side is closer then the passengers side . So the front left would come on just a bit sooner then the front right . But by making the line longer on one side the distance is now the same . Or balanced . Get it ? If it was just for body flex they could use rubber . Think about it if you kept flexing that line it would fatigue and brake . Dose the fluid get a benefit of cooling well yes . :D
poncho62 03-03-2012 06:51 PM
And you think Mr Obama is clueless.......... :rolleyes:
The correct answer is in post #2.....of this 5 year old thread........ :smash:
