why do break lines curl coming out of the master cylinder
im just curiouse as to why the break lines curl coming out of the master cylinder i have to run new break lines tomorow and needed to know if the spiral is relavant
brake line curl
They curl to absorb vibration. If you have rubber body mounts and the brake lines are attached to the frame there will be a slight movement of the frame while the master stays put.
That is correct, the lines make a loop to absorb movement and vibration.
Here is the last one I did. I usually wrap the tube around a piece of pipe to get the loop. At the body to frame juncture. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Thats good to know. I just replaced the master cylinder on a 74 dodge power wagon. It was a lot easier then I thought it would be. The brake line looping was one thing I couldn't figure out though.
You bored this morning Gary? That guy on the receiving end of that "vapor stream" would have benefited immensely from a little loop in that tube.Mikey
I get a big kick out of those and the CAVEMAN series.
Did I tell you my wife did the stand-ins for SASQUATCH?
and there is got to be nothing more seductive than to hear her say..." Honey can you rake my back?" She sounds HOT! Now back on topic...even a caveman can put a nice vibration loop in a brake line. hahahahaha mikey
They did it for that too. but vibration was the primary reason.
I always thought it was so the fluid could do a loop-d-loop..........That makes it happy................so it won't try to escape through a hole in the line...............
Ontario Rodders |
Brake lines
And you think Mr Obama is clueless..........
The correct answer is in post #2.....of this 5 year old thread........
Ontario Rodders |
| new master cylinder, bleed still no brake! | customdrumfinishes | Suspension - Brakes - Steering | 11 | 11-05-2006 07:07 PM |
| Master cylinder lines | mike rash | Suspension - Brakes - Steering | 2 | 10-01-2006 09:43 PM |
| need help on master cylinder | gun70runner | Suspension - Brakes - Steering | 2 | 06-22-2006 03:29 PM |
| Master cylinder sizing, dumb question? | baddbob | Suspension - Brakes - Steering | 6 | 06-19-2005 01:02 PM |
| Master Cylinder Problem need help!!!! | 71gtx | Suspension - Brakes - Steering | 2 | 05-23-2005 11:22 PM |
