Why do i get poor gas mileage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2012, 12:42 PM
I have a 51 ford f1 with a 302 & aod & the original 3:73 rear
I have an old holley 4 bbl on it-right now i am only getting 10-12 mpg
I thought that I should be getting better gas mileage than 10-12
any thoughts or suggestions would be appreciated,thanks Bob
Last edited by 68NovaSS; 10-14-2012 at 09:54 PM. Reason: No email address allowed in threads
Old 10-13-2012, 01:12 PM
How fast is fast enough?
an old heavy truck with a holley carb... that seems about right actually.
Old 10-13-2012, 02:10 PM
delawarebill's Avatar
bad mileage ???
i get about 15 in my bucket.. i didn't build it for fuel economy. what did u think u should be getting, or like to get ???
Old 10-13-2012, 02:28 PM
Irelands child's Avatar
Put a decent and clean 600cfm carb on it, check/replace the plugs, plug wires, put the timing at 9-10 degrees, make sure the vacuum advance canister is in good shape, air up the tires, make sure it really has a 3.73 ratio, not somewhere in the 4's like most of these trucks ran - then let us know. Oh and my 2300 pound '31 roadster with a mild 5.0/3.25 gears - gets ~15 -16 on its best day - it's a hobby car, not an econobox like the daily driver.
Dave W
Old 10-13-2012, 03:08 PM
that sounds good to me
Old 10-14-2012, 02:07 AM
JeffB's Avatar
Read a members comments on a Summit Carb also on a 302: Summit 600cfm 4v What intake manifold and distributor and camshaft are you running?
Old 10-14-2012, 05:37 AM
poncho62's Avatar
Wiki Edits: 5
Lose the Holley...
I also have a 51 F1, but with a 350 Chevy, turbo350 and 3.08 gears......I dont get much better than you. I have an Edelbrock carb on it, I think a 600. I know it needs rebuilding. I have a 500 Carter that I am going to put a kit in and try it.
Ontario Rodders
Old 10-14-2012, 02:03 PM
bigdog7373's Avatar
Of course it's fast
That seems about right to me too. If the bad mileage bothers you that much then you can look into fuel injection systems.
If you have a high stall converter and/or a lumpy cam that would hurt mileage too.
Also the way you drive has a huge effect on mpg's.
Old 10-14-2012, 02:17 PM
Banned User
i think the first thing to do is to determine that the actual way we are calculating mpg and that it is consistent and correct.
Old 10-14-2012, 03:56 PM
1971BB427's Avatar
Is this 10-12 mpg all around, in town, or on the highway. If it's in town it's good, if it's all around it's just OK, and if it's highway I'd say it's poor. I've got a mild 350 in a heavy '69 Suburban with TH400 and 3.73 posi, and I get 16-17 on the highway, and around 13-14 in town, with a 600 cfm Holley, headers, and dual exhaust. Heck, I get almost 13 with my car trailer and my gasser hooked behind it on the highway.
Gas mileage - one reason it's poor Irelands child Hotrodders' Lounge 11 05-22-2011 12:18 PM
Poor gas mileage problem ken47 Engine 3 03-19-2007 06:56 AM
Poor Fuel Mileage,Need Help BigDawgsEatFirst Engine 15 10-17-2005 09:49 PM
Poor fuel mileage lightemup Transmission - Rearend 16 11-06-2004 09:51 PM
Poor Gas Mileage 1bighawg Engine 3 07-30-2003 03:39 PM
