You could also go with the 4:1:1 acrylic urethane combo with Centari. If you look at the spec sheet the paint gets higher ratings mixed like this vs. spraying it as is. Basically they add the urethane elastomere to the reducer and call it "Performance Pak." If you do it that way the cans you get should say "Centari Ultra." It doesn't cost that much extra either.
