Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why does it die when I apply brakes?
Old 10-19-2012, 11:05 AM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Does it sputter some times or go off like a switch. Could be low fuel level in the float bowls. was a common issue back in the day. You would slam on the breaks or break for a few seconds and the motor would sputter right out. Could aslo be same problem in reverse with too much fuel.
Hope this helps.
