Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why does it die when I apply brakes?
Old 10-19-2012, 01:41 PM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Got cruise on it?
When you touch the brake, cruise will come off normally. If switch is screwed, it could kill the engine by backfeeding to ground.
Also, check the electric solenoid that sets up the carb idle, when ignition is turned on the solenoid will pull the linkage and add a couple hundred rpms to start engine and when turning the engine off, it will disengage solenoid and linkage to avoid run-on of engine. Engaging A/C also adds rpm.
