Why does it die when I apply brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 03:03 AM
jjj's Avatar
jjj jjj is offline
my 74 El Camino- stock 350/TH350 (not TH350C) has been running tip top. All of a sudden it dies when I apply the brake during idle- like at a stoplight.
I thought vacuum leak: Disconnected the brake booster hose at the intake and plugged the intake there... same deal!?
Anything else I can look at?
Old 10-19-2012, 03:51 AM
75gmck25's Avatar
Your first troubleshooting sounds reasonable, so I'm surprised you did not find a bad brake booster that was screwing up the vacuum.
However, if its not vacuum, then maybe its electrical. Something may be grounding out when you press the pedal, or a sudden electrical load may be causing such a draw on the alternator that it pulls the idle down very quickly and it dies.
- Hold the brake pedal down and start the car. Try this in several positions of the pedal travel. What you are looking for is a point where something grounds out and causes an electrical problem. If you have an aftermarket tach, take a close look at the wiring to the HEI to make sure you don't have a wire running next to the brake pedal arm that is grounding out the ignition.
- Try pulling the fuse for the brake lights to see if it resolves the problem. I don't think the lights could put enough load on the alternator to pull the idle down significantly, but maybe something else (add-on 3rd brake light?) is drawing excessive power. Check for any relays that might be connected to the brake light circuit. If someone has added any aftermarket security devices, that would also be a good place to start.
Bruce
Old 10-19-2012, 06:05 AM
Last journal entry: was hoping for better than this
look for a pinched wire under dash thats getting pinched when your on the brake..
or a loose ign switch on the column at the base..
Old 10-19-2012, 12:41 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Got cruise on it?
When you touch the brake, cruise will come off normally. If switch is screwed, it could kill the engine by backfeeding to ground.
Also, check the electric solenoid that sets up the carb idle, when ignition is turned on the solenoid will pull the linkage and add a couple hundred rpms to start engine and when turning the engine off, it will disengage solenoid and linkage to avoid run-on of engine. Engaging A/C also adds rpm.
Old 10-20-2012, 01:42 PM
jjj's Avatar
jjj jjj is offline
I am certain that the condition exists even when the brake booster is taken off-line. I will search under the dash to have a look at the brake pedal switch. I am not certain that the switch could be the cause of the problem- not sure where or how the switch could cause a ground strong enough to kill the engine... any other ideas are welcomed.
Thanks in advance.
how apply clear coat when the base coat was apply a while ago Vincentnova Body - Exterior 8 07-21-2011 10:14 AM
200R4 2-3 apply timing larrym Transmission - Rearend 4 04-10-2010 02:30 PM
anyone ever apply for a patent/need help deadbodyman Off-Topic 34 09-10-2009 06:10 AM
How to apply black paint hgufrin Body - Exterior 23 06-11-2008 06:04 AM
Where to apply 2K primer? starquest Body - Exterior 3 06-01-2005 05:39 AM
