Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why does fuel pressure drops when electric fan turns on
Old 03-27-2005, 11:39 PM
Palmtrees57chevy Palmtrees57chevy is offline
New Member
Hey guys, thanks for the replys, it seems to me that the rpm doesn't change when the fan comes on. So if it is slowing down I can't tell. The idle is set around 750. To answer chevfreaks question, I was told before to install an electric pump in the system to solve the problem, but it didnt stop it. So now I have the electric pump as well as the mechanical pump on the truck. So is the 100 amp alt too small? I have gone to numerous car shows and have looked at other guys set ups and mine looks just like most that I have seen, nothing special. So I don't understand why "I" am having this problem! I have braided lines running from the pressure regulator up to the pressure gauge. From the pressure gauge is the filter then a hard line to the carb. I have even tried putting on some insulation over the regulator up to the filter. It didnt stop the pressure drop. I am all out of ideas!
