Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why does fuel pressure drops when electric fan turns on
Old 03-27-2005, 10:50 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Does the fuel pressure return to normal when the fans shut off? Or does it just fall off when it is warm? I would suggest running a seperate electric pump and seperate fuel source (like a 5 gal. fuel jug) to the carb with temporary lines, and try that. If the thing runs like a top, your plumbing may be at fault. If not, I think we may need some more info.
