Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why does fuel pressure drops when electric fan turns on
Old 03-27-2005, 11:23 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
If it still does it with the cap off, I doubt it is a venting problem. Almost sounds like a vaporization issue. I'd try the external fuel source, both through temporary lines, and through the existing setup. This will eliminate either the tank, venting or the lines. I'll think on it overnight and thriugh work tomorrow, maybe have a look at a couple of Ranger tanks I've got kicking around the shop, and get back to you tomorrow evening, as it is nearlt 1:00AM here. Talk to you later,
Freak.
