Why does my brake booster fill up with petrol - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2013, 12:37 AM
I took my brake booster apart to see why brakes weren't working properly
And it was filled of fuel. I have a 671 supercharged sbc running 2 quick fuel
Carbs the brake booster hose is on bottom carb plate can eny one till me
How I can solve this problem
Old 11-10-2013, 09:03 AM
S10xGN's Avatar
Gotta love a turbo!
You should have a check valve in that hose. Not just blown cars but all vehicles should...
Russ
Old 11-10-2013, 08:11 PM
Freddy62's Avatar
On most cars with blowers, the carbs are considerably higher than the power booster... gravity takes care of the rest.
If you have the room, I would consider adding a 90 fitting on the inside of the carb base that would point down toward the rotors of the blower. I would think that would take care of most of the problem.
Old 11-15-2013, 09:08 PM
Thanks guys for your help both of those things
Helped
making a remote fill brake reservoir Ed ke6bnl General Rodding Tech 6 01-20-2013 07:32 AM
brake booster mafiacustomz Suspension - Brakes - Steering 3 07-23-2011 08:56 PM
67 brake booster help my52 Suspension - Brakes - Steering 3 03-01-2009 12:10 AM
Brake booster kgbronco Suspension - Brakes - Steering 4 01-05-2009 07:45 AM
remote brake reservoir fill HOT 'N' HVY Chevy Suspension - Brakes - Steering 2 11-06-2006 05:25 PM
