Why does washer kit have plastic
Bought a thrust washer hit for the th350, has two plastic ones that to me seem useless. Thoughts?
Do you have something against plastic?
Lots of tranny thrust washers are plastic. |
So I got the entire inners together all but the front pump and these were to be in there somewhere? I put a metal one everywhere it was logical to have a washer and I'm left with these. NO PLASTIC CAME OUT when disassembling
Much like a carb kit, it's easier to include a couple small parts that aren't used in every app, than to stock several more part numbers. Your tranny parts pack might be similar. |
Some th350's have a plastic and some have a torrington for the thrust bearing behind the pump.
There is definitely a thrust washer behind the pump. Install the pump and check the endplay. |
make sure you check end play of the output shaft as well as the input shaft.the snap ring to the center support is basically the stop to check end play for the output shaft. it is just as critical as the front end play. |
Two washers were often plastic type of material... the washer next the drive shell as mentioned and the washer on top of the ring gear on the front planet.
use metal or plastic , what ever flips your skirt
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Here's a pic of a copper/babbit? and torrington bearing type.
You can use shims pictured to take up too much end play. |
| 4L60E Shift kit. | GMCTRUCKS | Transmission - Rearend | 8 | 05-20-2012 03:22 PM |
| 4L60E rebuild kit ????'s | Turbonoma | Transmission - Rearend | 0 | 04-14-2007 12:10 PM |
| DeVilbiss Finishline kit w/ small compressor? | mikeweb | Body - Exterior | 6 | 03-18-2007 01:18 PM |
| where to get a quality 383 stroker kit ? (Long) | Mustangsaly | Engine | 1 | 07-18-2006 06:13 PM |
| Lift Kit | CustomFord | Suspension - Brakes - Steering | 1 | 05-09-2006 03:21 PM |
