Why does it wobble - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 09:14 AM
Why does it wobble
I am a 15 year-old and i am restoring a '59 chevy truck. I was wondering why my steering wheel shakes back and forth even when the truck is still?
Old 05-24-2012, 09:41 AM
blwn31's Avatar
Sounds like the steering box is worn and needs adjustment, or replacement if the wear is bad enough. Glad to see you young guns taking on an old project. It's gonna be a nice ride when your done.
Keith
Old 05-24-2012, 10:16 AM
boatbob2
wobble..........
Sounds like you have play in the steering box,or,its worn out. on the top of the box,you will find a nut,holding a stud with a screwdriver slot,(usually) loosen nut,using a screw driver turn stud in (clockwise) about 1/4 turn,tighten nut,check for steering wheel play,still loose? do the adjustment again,only 1/4 turn at a time though.keep going,unless the box is worn out,this SHOULD fix the problem...BUT,it could also be worn out suspension components..(bad ball joints,or tie rods.) have a friend move steering wheel (rock it)while you look at the front end parts.do this,BEFORE adjusting steering box..
Old 05-24-2012, 07:48 PM
Cape Cod Bob's Avatar
Why does the movie "Christine" come to mind.
Old 05-24-2012, 09:36 PM
Wiki Edits: 27
double check before driving
If the wear is bad enough in the straight ahead position you could tighten it too much and not be able to turn, or be very hard to turn .
Old 05-25-2012, 04:27 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Or when turning it will not return to center on it's own, you will have to manually turn it back...not safe.
death wobble tommyboy8072002 Suspension - Brakes - Steering 21 05-15-2012 07:32 PM
Ballancer wobble...? UR50SLO Engine 11 03-30-2007 08:14 PM
wheel wobble ls67 General Rodding Tech 7 08-19-2006 11:47 AM
Wheel wobble jamn50 Transmission - Rearend 2 04-05-2006 06:21 AM
Wobble in flywheel ok? bartamos Engine 3 07-25-2005 07:58 AM
