why doesn't my car cutoff - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2005, 12:49 AM
New Member
hello again why doesn't my car cutoff when i turn the ignition back to off i have go up under the hood unhook the battery and turn the the ignition like am trying to cut the car on.this is really pissing me off
Old 05-20-2005, 01:23 AM
tbirdscott's Avatar
stuff'n things'n whatnot
What kinda car?
Old 05-20-2005, 03:42 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I'll trade ya, I have one that won't start!
Old 05-20-2005, 04:19 AM
docvette's Avatar
Wiki Edits: 12
Cut off
Doc here,
A few things will cause this malady, A Short in the primary Ignition source to POWER...A Short OR mis-wire in the SECONDARY Ignition Circuit to POWER, OR you may need a diode on the Alternator power lead...or an electric Fan lead...and it could just be a bad Ignition switch (internally shorted to power)
You need to find where your coil is picking up power from when the switch is "OFF"...measure the coil wire with everything off and the battery hooked up...It should be zero...no voltage...If you find a voltage there, remove the fuses, one by one and see if the power goes away,If it does, you have a short in that circuit...
If that's all good disconnect the secondary ignition line from the solenoid, (If so equipped) If the power goes away, replace the solenoid (or find another switchable constant power source for it) If it does not go away follow the wire for any short to power.
If no power is present when you hook the battery up in OFF, but remains there after you shut the key off, and all the above is good, you may need a diode in the alternator, Disconnect the alternator, fire it up and shut it down, does it quit? If so..you need a diode.
What year model and engine displacement are we talking about here? Stock or aftermarket harness? Newly installed Electronic Ignition?
Try the above, answer the questions and we might be able to help you better.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-20-2005, 12:01 PM
New Member
Originally Posted by tbirdscott
What kinda car?
it is a pontiac bonneville with a 403 olds motor
Old 05-20-2005, 01:47 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
Does it have and MSD type ing.?
Chris
Old 05-21-2005, 11:11 AM
New Member
Chris
i really don't can u described it i am new at this stuff
Old 05-21-2005, 11:45 AM
You wouldn't happen to have any pictures would you?
There would be box in the engine bay with wires going to the batt.
red box upper left hand side. Your could be any number of colors but it should have a little box there *This is for ele. ing. only*
Chris
Old 05-21-2005, 11:26 PM
New Member
Chris
no my car doesn't have it just have a distributor
Old 05-22-2005, 07:47 AM
Have you recently swapped out the alternator for a newer chevy one? if so you may have the wires switched and that would cause the motor to keep running even after you shut if off.
Gary
Old 05-22-2005, 08:48 AM
OddRodder's Avatar
CORNFED and INBRED !?!
Is it an H.E.I. distributor? With the coil mounted in the center of the cap? When did the problem start? Have you wired in a new tach, stereo component, or anything else resently?
1985 LTD 302 V8 Cheap begginer project car 1stPROJECTcar Engine 5 05-27-2011 03:18 PM
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
