Why a drag car crashes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 04:48 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
When suddendly a drag car turns to one side and crashes, is it usually due to a broken axle or what else?
thanks
Old 10-26-2012, 04:49 PM
poncho62's Avatar
Wiki Edits: 5
Tire blows........suspension part breaks.........
Old 10-26-2012, 04:53 PM
Last journal entry: was hoping for better than this
water under one tire/ oil too
Old 10-26-2012, 05:06 PM
Faith - Respect - Trust
Could be anything, even the torque of the engine when coming off the line can do it if the driver either under or over compensates for it. It could be anything, maybe he spotted a McDonald's drive through one block over and had to have a Big Mac like right now.
Old 10-26-2012, 05:18 PM
so many things debris on the track, broken axle, oil, water, getting out of groove, its funny how hard going in a straight line can be lol
Old 10-26-2012, 05:23 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Bump steer is another factor..
Sam
Old 10-26-2012, 06:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks
With low down force drag cars like Pro Stock, anything that gets them out of a straight line by only a few degrees will cause them to lose control. This is often caused by a loss of traction, but could be any number of things like a flat tire, broken suspension or driveline parts, steering overcorrection, wheelies, wind gusts, bumps, debris, or irregularities on the track, etc.
That's why you see them lift and immediately pop the laundry when they get out of shape. The chute works to stabilize the car and helps bring it back into line.
Old 10-26-2012, 06:36 PM
I don't know, I've seen old W.J. pedal quite a few out of shape prostocks..
Old 10-26-2012, 06:49 PM
prostreet6t9's Avatar
Differential/Driveline
A broken axle will do it also. With the Prostocks.. If the track is not prepped good they can get pretty scary at half track. They Just don't have as much Downforce as the the Fuel guys.
They had the problem 2 or 3 weeks ago and 1 car crashed pretty bad.
Colbalt holeshotted me... lol
Old 10-26-2012, 06:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Warren's mad skilz aside, today's Pro Stock cars are so on the edge that if they're not driven perfectly, there's no saving them once they're out of shape, unless it's in the first few hundred feet:
Old 10-26-2012, 09:01 PM
Augusto's Avatar
being watchin this videos and a lot more, and seems like mosf of them over-correct when the car drifts sideways, seems like as monster76 said above "its funny how hard going in a straight line can be"
thanks a lot guys, learned a lot with this thread.
Old 10-27-2012, 05:20 AM
Jimbo17's Avatar
Nostalgic Racing Decals
Tires
Many times when you see a car get into the wall what's happening is one tire is hooking up better then the other tire and there are a number of different things that can cause this to happen.
Every watch the crew when they are staging a car at the line and one crew member is putting chalk on the wheelie bar wheels?
Once the car launches they then look at the marks on the payment to see if they are both the same lengths? Tells you a great deal about the chassis and it one wheel in hooking up better then the other.
There are also many ways to fix these problems but getting the car to go straight down the track takes work and know how for sure.
Getting a car to launch right and go straight takes a great deal of work.
Another problem for many drag racers is that when they launch with the front wheels off the ground the rear wheels and the horsepower of the engine are simply pushing the car from the rear so getting out of the groove can sent you right into the wall.
In circle track racing you have a similar problem but it's known as pushing which is when you get to a corner and even thought you have the steering wheel turned you are still heading straight for the wall unless you lift.
The rear end is over powering the front end of the car.
Jimbo
Old 10-29-2012, 07:04 PM
Once a car like a pro stock gets just just a little out of shape it goes from having very little if any down force to actually having lift. Unlike nascar cars the have no system to kill this lift. I don't see why this couldn't have been corrected years ago. Is someone going to die before they get a hadle on this?
Old 10-29-2012, 08:38 PM
Augusto's Avatar
the parachutes should deploy automatically when a sensor detects some veering, this should be mandatory.
Old 10-29-2012, 08:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The fuel classes have an automatic chute release anytime the engine blows or lifts the burst panel or even if the driver doesn't follow the shut down sequence correctly after the finish line. This is combined w/a fuel cut off, maybe ignition too but not sure on that. But they don't use it on Pro Stockers, and for the life of me I do not understand why not.
I agree w/you on the chute release once the vehicle veers off course. This would be quicker than a driver could react- and could save cars from crashing and maybe save a life someday.
The idea of having roof flaps like NASCAR uses might be a good idea. The only problem as I see it is there's such a short distance before a drag car hits the guard rail compared to a stock car sliding across the track that the roof flaps might not have enough time to do their job. Still, I'd like to see it tested out at least.
What Is the best Drag car and why Dan1990 General Rodding Tech 19 11-14-2012 06:03 PM
Would you consider an All Drag Car a Muscle Car? MXrider13 Hotrodding Basics 27 09-06-2011 07:19 PM
NASCAR plane crashes into houses & kills 5 Rob Keller Off-Topic 1 07-17-2007 04:11 PM
Street car or drag car? HemmiGremmie Hotrodders' Lounge 9 12-13-2004 01:36 PM
