Hotrodders Bulletin Board
#1
Why high RPM's on the oval tack?
Hi everyone,
Ok so I was looking in another thread and and asked a question and I was told it was due to the fact that circle track cars like high rpm's. I was wondering why? I realise that hp is usually made at the top of your power curve but torque is made at the lower middle {depending on application/engine}. So wouldnt you want the torque to be able to pass someone? Which would usually mean lower rpms, correct? Ive been looking at some speed formulas and they seem to pretty much say that the more rpm you have the more speed is available but since oval tracks arent typically that long wouldnt you want the torque to be able to pass someone? ....Ok Im confused someone please shed some light for me. |
#2
re: Why high RPM's on the oval tack?
Comes down to technology(today) and rules of the racing organization.
If you need to have 352,377,400,350 whatever, cubes thats what you get to make power with. Also I believe rear gears can also be dictated to the field. You would have to run some weird(high overdrive) gears to keep the engine speed down and vehicle speed up, and I dont think its allowed in most competition levels or any for that matter. Back in the day they didn't turn 9-10k with the modified production engines because the technology wasn't there. It is now, so they can do the tremendous RPMs and keep it stable. I bet johnsongrass could tell you a lot better/detailed info on current and days of old specs as he actually does this stuff. |
#3
So your saying there is no real reason to it? Just that technology allows them too so they do it?
Steve |
#4
Well if your allowed a 1:1 final and a 3.55:1 rear gear and you want to go 160mph that engine is going to scream.
And some classes specify rear gears. Could be lower or higher, which would intern change the peak RPM range and peak MPH of the field is capable of. Then its just up to you to make the most power with your cam/compression/timing/etc |
#5
Right and technically the more rpm the more speed? Then when you make more power {more so torque} that will give the passing power you need while maintaining your high speed? Am I correct so far?
Steve |
#6
Well lets say an engine is turnin 6000(peak power,safe(stable)) and going 150-160MPH
assume same gear ratio's now the engine is spinning 9000 and going 180-190MPH. And its not just the stroke that changes the total overall engine speed. The valvetrain has the biggest say in what you will get away with. |
#7
Ok now I have two more questions. These engines, while one is turning 6000 and the other is turning 9000. Do they have the same power? If the 6000rpm has 600hp/tq does the 9000rpm also have 600hp/tq? My point is does the rpm difference influence the speed or is it the power that comes with those rpm?
Now what factors of the valvetrain limit how far an engine can rev? Thanks Steve |
#8
Engine size is a factor. The best way to increase the power potential of an engine is to add cubic inches, increase the rpm potential or force more air down its throat (which I would think could be related to adding cubic inches).The big blocks they ran in NASCAR 40 years ago were somewhere around 70-80 cubes larger than the 358ci they are limited to today. How many N/A 358ci V8s do you see making 750hp at 6000 or 6500 rpm? The Honda S2000 engine is a good example, when they first came out they had 2.0L (120ci) engines that were rated at 240hp at 8900 rpm. The later versions continued to make 240hp but bumped displacement up to 2.2L (131ci) and the power peak dropped to 7800rpm.
Here is a related question I asked a few months ago: http://www.hotrodders.com/forum/big...ore+Long+Stroke Quote:
Weight is a huge factor, the ability of the spring to force the valve shut and hold it shut at high rpm. Since things happen so incredibly fast at 8000 rpm the camshaft has to open the valves far enough and long enough to allow the cylinder to draw in enough air/fuel to make power in those rpms. And as we all know cams designed for that kind of use aren't conducive to low rpm duty. Useless info: Did you know an engine spinning at 8000 rpm completes the four stroke cycle about 67 times per second? The intake stroke on an engine spinning at 8000 rpm only lasts about .007 seconds. Last edited by Blazin72 : 05-15-2007 at 08:23 PM. Reason: Added useless info... |
#9
Very high duration cam. Tight/high spring rate valve springs (dual - triple) to close the valves very fast. Also additional measures to keep oil on the coils to cool them off. Anything to prevent floating the valves and spring failure from heat. Takes lots of money, and I am pretty sure the component lifespan is not as long.
The faster spinning engine will make more power with same bore/stroke. |
#10
Blazin72 hit the nail right on the head. The more air you move through the motor, the more horsepower you make. A larger engine moves more air, so all else being equal, it makes more power. Forced induction is another way. Virtually all racing series are displacement limited, and other technologies like porting, valve sizes, and carb size are also mandated by the governing body. The only way to make more power with a fixed displacement and these restrictions is to rev higher.
Unfortunately, it's now time for a little math: A 358 cu in engine at 7000 RPM moves about 725 cubic feet of air per minute through the engine (358/1728 = .207 cu ft of displacement, 0.207 x 7000 / 2 =725 cfm. Note the 7000 is divided by 2 since there is only one intake stroke for every two revs). Now this same engine at 8000 RPM moves 828 cubic feet per minute and ideally should make about 14% more horsepower. Yes, these are idealized numbers and the reality of port flow, restrictor plates, mixture distribution, etc, etc all have effects, but this is why higher RPM is better. Note that this 358 at 8000 RPM moves as much air - and all else being equal should make as much power - as a 427 at 6700 RPM. |
#11
It is mainly a function of circle track cars running a lap in the same gear, and a limited amount of rear gear options, given the track diameter is fixed. You design a circle track engine to peak RPM at the end of the straight and make the highest amount of torque (and therefore horsepower) at the RPM the car will be coming out of the corner at. This gets you out of the corner hard and pulls throughout the straight for continuous and maximum acceleration. To make an engine run hard from the exit of the corner to the end of the straight, with one gear, requires and engine that will continue to make power into the upper RPM band, as compared to a stock type motor.
#12
Oval Track RPM's
Blazin72 was very close to the correct answer to your question. They adjust the final gear ratio to the track that they race on to keep the engine in the right powerband. RickWI was even closer to the right answer! They build the engine to suit the track that it is run on. Yes it is designed to make max torque coming out of the corner and max HP at the end of the straight away. What you may not understand is that the basic engine building rules for the street that you are use to don't apply on the race track! These engines have the camshaft ground specifically to suit the application that the engine will be used in. The heads are ported and intake and exhaust manifolds/headers ported to suit the particular application where this engine will be used. My Kudoos to RickWI for suggesting the proper answer to this question! All I did was expand on it. Thanks, RickWI, Yours, westfaliaguy.
#13
It's a matter of design efficiency. Horsepower is a measure of torque in time, this is what does work. Torque by itself is simply a force. An engine in a race car turning at 9000 RPM develops far more horsepower (therefore, does more work) than the same size engine turning at 6000 RPM. To do the same amount of work at 6000 RPM would take a larger motor. These are the underlying physics of the situation. A larger motor takes more space, adds weight and in and of itself requires even more power to get the job done. A good example of this is drag racing shortly after World War 2. At that time there were a lot of big military airplane engines on the market, like the Rolls Royce Merlin. Of course the fast guys thought the fast way to beat a little old Chrysler Hemi powered drag car would be to build a car big enough to hold one of these 2,000 horsepower airplane motors. It didn't work, the power needed is geometric function of weight and drag. With the physically huge engine, the weight and drag penalties went up way faster than the power and the things weren't competitive. So when the rules constrain the size of the machine, there is some optimum physically sized engine. In the classes you refer to, the small block Chev, Ford or Chrysler long ago became recognized as an optimal solution. The improving technology over the past few years has only made these engines even more competitive as RPMs and power has gone up without a corresponding increase in size or weight. Bogie |
#14
The answer to this question is quite simple, and we need not confuse it with too much discourse.
We want as much torque at as much RPM as we can produce, and we want to be able to harness it, and apply it to the ground. Modern stock cars are far more advanced from a chassis stand point and we have gotten much better at applying that to the track. This is why we are seeing larger engines, turning more RPM than we used to see. The chassis technology of the old days and with the old tires, would allow this to happen, but we can now get away with it. A 301 Chevy in the old days would turn as many RPM as most modern engines we are seeing now, but obviously, the larger engines produce more power. |
#15
Hey everyone! Sorry for taking so long to reply, Ive been trying to get the engine out of my car
Steve |
Back to top |
Similar Threads for: "Why high RPM's on the oval tack?"
| too high rpm help | jcdaly | Transmission - Rearend | 25 | 01-31-2005 07:03 PM |
| Altima RPMs drop while driving suddenly, can't maintain speed, can't start sometimes | elukas | Electrical | 1 | 10-07-2004 01:31 PM |
| high volume and high pressure oil pumps can destroy cam and distributor gears! | Knobie | Engine | 64 | 10-11-2003 04:08 PM |
| Permatex High Tack same as gasgacinch? | brian400ex | Engine | 4 | 02-13-2003 06:13 PM |
| erplexing rpms | madhat | Engine | 2 | 01-12-2003 03:53 PM |
