Less power (torque)
Less bottom end..... There is an old saying...."There is no substitute for cubic inches"
Ontario Rodders |
Yeah, but then turbos were invented.... and don't forget nitrous!
Sure, a turbo'd big engine will produce more power than the same N/A, but a small engine with a turbo will produce as much as a much larger N/A engine... therefore in some cases there IS a substitute. Pretty much the same iwth nitrous, but those little engines better have strong bottom ends! |
Cost, Man....Cost.
Dollar for dollar.................Cubic inches are free....................or, cheaper anyways
Ontario Rodders |
I agree with less tire spin, but not necessarily more top end. The smaller motor might run more RPM before the hp starts to drop, but probably not make more peak hp given the same setup.
Check this out. It is a 350 and a 383 with the exact same parts. The 383 makes more peak hp and more peak torque, but at a lower RPM. I believe the same would occur between a 327 and a 350. http://airflowresearch.com/articles/article72/A-P1.htm Adam |
| DZ 302 Vs 327 ???? | oc00l | Engine | 37 | 11-18-2008 09:53 AM |
| help make my 327 angry!!! | 70chevelle327 | Engine | 41 | 04-24-2007 05:33 PM |
| 327 build up using 1964 and earlier parts ONLY | chopperimpala | Engine | 23 | 10-06-2005 01:07 PM |
| 327 TO 350 CONVERSION | 34FordPickUp | Engine | 4 | 08-27-2002 05:56 PM |
| 327 rebuild help. SUGGESTIONS PLEASE | DeezImpala | Engine | 1 | 06-24-2002 09:06 PM |
