Why lacquer paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 12:28 PM
acrylic lacquer paint
Thanks for reply.Lacquer paint is still available.PPG still makes it in many colors as well as many original colors from the 1930's to present.Markl
Old 11-06-2005, 12:42 PM
Why lacquer paint
I have used lacquer in the past.It is very easy to work with and looks really good once rubbed out.The car dont see much road use just a cruise once in a while, and a burn out in the garage!
Old 11-06-2005, 12:45 PM
roger1's Avatar
Yea, I checked my PPG dealer for lacquer a few months ago and it is available.
They said that they could only sell it to individuals and not to businesses.
Don't know whether that is State or Local rules.
I live in Austin, TX.
I ended up going with the single stage urethane (PPG Global DG) for my Vette.
Still looks like lacquer when color sanded and buffed but get the extra durablility.
Old 11-06-2005, 12:57 PM
roger1's Avatar
Your right, lacquer can be good for your use or for an authentic restoration.
I've done both lacquer and SS urethane on older Vettes. (non-metallics)
Can't say lacquer is any easier to work with than the ss.
Laquer is harder in that you have to put on more coats.
SS is a little harder to color sand.
SS looks better in the door jams where you don't color sand (unless you are anal).
Overall, about the same amount of work.
Why not go with ss and get the durability?
Chipping, cracking, holding up from the sun all better with ss.
In any case, never use lacquer primers. Everything under that paint should be a 2K product. So, you should be equipped to handle spraying products containing ISO's anyway.
Old 11-06-2005, 07:56 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I guess after some real-life experience with a car painted with Duracryl acrylic lacquer, I would not want to do it again! As a finish for a concours car that never sees the outdoors, great. Nothing buffs out like lacquer, it is truly a marvel to behold! For a real-life car that will even occasionally be exposed to things like bird poo, tree sap, or even a rare incidence of gasoline spill, just wait and see, it can be miserable!
Old 11-06-2005, 08:12 PM
Laquer was easy, fun, and looked great when fresh but it sure doesn't hold up like the urethanes available today.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
Can I put clearcoat on top of a lacquer paint viperACR Body - Exterior 10 06-18-2004 10:44 AM
