why is my 400 trans shooting the fluid back through the filler tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 10:31 AM
New Member
hey my name is carl my trans is shooting the fluid back through the filler tube once i put it in drive
Old 05-12-2005, 10:57 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
possibility
If your tranny cooler lines are kinked, clogged, or have sharp bends. It will cause the fluid to come out the dipstick.
Old 05-12-2005, 11:49 AM
Last journal entry: PICTURE TEST
trans
You really did not give us a lot to go on.... Was this a new rebuild??? Has it always done this or just started out of the blue??? Does this happen only when hot or when cold also?????
A blocked vent tube will also cause this to happen....
keith
Old 05-12-2005, 09:17 PM
New Member
the 400 trans
the tranmission is not rebuild when i drop it in the pontiac it had started to do the thing i told u.It starts this as soon as i put it in drive when the motor and trans is cold it shoots it back through the tube and get over everything iin the engine compartment
Old 05-12-2005, 09:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
tranny too full?
vent clogged?
keith
Old 10-31-2006, 09:39 PM
tranny shower
My Bentley Mulsanne came with a GM turbo 400, and one month AFTER having it rebuilt she threw up 2 1/2 quarts of fluid. The rebuilder changed out a "modulator", and that solved the problem for 4 years. This problem came back just yesterday... I will drive her back to the Doctor tomorrow and post the part number that will be changed.
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 03:46 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Filler Spout for Trans horvath Transmission - Rearend 2 06-18-2003 05:06 PM
B;owing trans fluid out the fill pipe Sandman Transmission - Rearend 5 06-05-2002 08:29 PM
