Why is my convertor locking up - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2010, 11:42 AM
Hey guys need some advice,put a 700r4 (from 1985 camaro z28) into 1985 s10 blazer(w/ v8) found out there was no12v source to trans so I ran one to the "a" pin no difference with it hooked up or not,but trans acts like it is locking up since it will stall the engine at stop. Trans was rebuilt(w/upgrades) by a reputable shop and a shift kit was installed also has a 2600 stall converter. Trans isn't as bad about stalling the engine, if you shift into neutral ,stop and put it into park for a short while then start again but when you stop again same thing all over. Seems to unlock after it sits for a while either idling or shut off.
Old 11-28-2010, 04:49 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
it sounds like you have it on a continue 12 volt but it needs 2 be on a switched positive wire so you can try 2 hok it up 2 a toggle switch so that you can manualy turn it on and ff or they aslo make a kit to engage and disengage it
Old 11-28-2010, 07:07 PM
Have the 12v through a toggle switch and also through the brake light switch works the same on, or off, or unplugged altogether, converter will lock up without any power supply to the trans and does not unlock when stopping. Thanks for the reply.
Old 11-28-2010, 08:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The 700r4 trans was engineered by GM with no oil for lock up in 1st gear to avoid the problem you describe.
There usually is a cross leak in the pump or valve body or mis match of parts to cause this.
You could drop the pan and check the lock up solenoid and valve for proper operation.
Old 11-29-2010, 07:20 AM
Thanks for the reply, maybe I can avoid having to remove the trans it's pretty much a dog in a s10. thanks again
Old 11-30-2010, 08:56 AM
check to see if rebuilder installed a hydraulic lock up valve where an electrical wire is not needed if so maybe valve is sticking.
Old 12-01-2010, 08:24 AM
81 Vette
I agree. If this is not the case then its the lock up solenoid. They are prone to failure and will put the trany in full time lockup even without power. Drop the pan and remove the soleniod, you can bench test it with a 12 volt source
Old 12-01-2010, 09:06 AM
Thanks for the info. The solenoid is the original one. I plan to replace it with a new one(universal two wire). If I understand what I've read correctly can I connect the red wire to a 12 volt power supply through a toggle switch, the black wire can be grounded to the solenoid mounting bolts and not use the other switches and this will allow manuel lockup control, is this correct?
Old 12-02-2010, 07:35 AM
Since the solenoid is something I can do myself that will be my first choice . I've purchased a two wire solenoid (one red wire and one black wire) If I connect the red wire to a 12v source(through a toggle switch) and the black wire to ground at the solenoid mounting bolts and not to the other switches will this be the correct way to have manual lockup? Just wanted to make sure I understood all the info. Thanks for your help
Old 12-02-2010, 07:46 AM
is there a switch for the converter on the brake pedal? factory equipped 700s had this to disengage the lockup
Old 12-02-2010, 08:00 AM
Yes I have the 12v wire through the toggle then through the brake light switch in case I forget or have to stop quickly Thanks for reading my post
