Why is my critter gun doing this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2010, 05:23 PM
But it is shooting out the glue on the material the way it should.
Old 09-24-2010, 01:34 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You need to adjust the lower vertical nozzle. You're getting a little too much fluid. The nozzle can be turned in or out. You can also lower the air pressure to the gun.
My Critter does the same thing, but it's because I shoot the glue at 80 pounds of pressure like I use on my other pneumatic tools.
Old 09-26-2010, 09:44 AM
camberoz's Avatar
i have been having the same issue and i can never seem to get it to spray right
i am picking up a new compressor this week hoping that helps out
Old 09-26-2010, 10:11 AM
Wiki Edits: 22
You have to remember that this type of glue is at the upper limits of what this sprayer is intended for. It is intended to spray things like stain and varnish, and the foam to foam glue is just a little thicker than the sprayer is able to handle comfortably. I have been using one of these for over 30 years, and it has always done this. It's annoying, but the sprayer still functions correctly.
Old 09-26-2010, 10:35 AM
Exactly! But I recall K Grip saying something about using there thinner to thin the stuff out.
Old 09-26-2010, 12:14 PM
Wiki Edits: 22
Do not thin the K-Grip glue or DAP contact adhesive, it is meant to spray just as it is from the can.
Why are you worried about this anyway? You're not trying to get a glass like finish like painting a car.
Old 09-26-2010, 01:35 PM
that's true.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
