why is my paint gun spitting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2005, 10:49 PM
I know it's hard to diagnose problems but some ideas would be helpfull.
I've got 4 diff guns, none of whch are top quality but they seem to work good. problem is last couple of times I used them they were spitting, in about 1 second intervols. The gun I used today is a astra 4014 but it also happend last time and I swiched guns and did the same thing so I guess it's the compressor. 5 hp oiless 20 gal 220 blackmax. The guns all worked real good before. Any ideas. Like the gun shoots a nice pattern then after 1 second spits(no paint) then shoots a nice pattern. When I do air only it does not do this. when I do thinner, it does not do this. The paint seems pretty thin and lays nice until it spits. Any ideas? its really pissing me off. Thanks for the help
Old 11-23-2005, 11:00 PM
staircasesurfer's Avatar
alex p
Last journal entry: AHH
i have heard to check the breathing hole on the top of the cup and make sure that the air valve on the bottom of the gun is open
hope that helps, alex
Old 11-23-2005, 11:04 PM
no valve on this gun just a nut (Not Me )
also I took the top off the cup and tried it, no diff
Old 11-23-2005, 11:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Are you straining the paint?..sometimes a small bit of trash might get in there..
OMT
Old 11-23-2005, 11:18 PM
no
Old 11-24-2005, 02:20 AM
milo's Avatar
point on positive
Remove the air cap off the gun. tighten the fluid tip a little tighter (even if you think it's already tight) and replace the air cap...
9 times out of 10 this is caused because we don't want to hurt our paint guns by wrenching on them. Tools are our best friends... It's got to be tight there though.
http://www.a2zautoforums.com/showthread.php?t=3367
Old 11-24-2005, 07:25 AM
slammed88
How are you cleaning your guns? I have had problems with just trying to blow solvent through them and setting on the shelf. Next time I went to paint the thin film of clear that the solvent didn't completely remove partially restricted the tip and didn't spray well at all. I now take apart and clean carefully after each use...only takes a few minutes
Old 11-24-2005, 10:40 AM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
I have experienced this same problem recently and after a good clean it worked fine.
Old 11-24-2005, 11:51 AM
mrcleanr6's Avatar
make sure the needle packing is tight. if there isn't a good seal around where the needle goes through the gun then it can suck air. usually it will be a rapid sputter but your might be a very slow leak. just a possibility.
Old 11-24-2005, 12:09 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I second the packing nut check!
Old 11-24-2005, 03:43 PM
no substitute for experiance. Thanks guys. I tieghtened the fluid tip and it works like a charm
Old 01-19-2006, 11:41 PM
milo's Avatar
point on positive
9.03 times out of 10
thanks for survey feedback
Old 02-20-2009, 10:32 PM
deadbodyman's Avatar
Wiki Edits: 11
guns
sounds good just dont use pliers
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
paint gun deuce_454 Body - Exterior 4 02-04-2004 04:08 PM
