Why positive camber on my M II suspension? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2010, 03:35 AM
staleg's Avatar
Last journal entry: Hand brake
On my Fat man M II kit the alignment specs are:
-1/8" toe in.
-0,5 degree positive camber.
-1,5 degree positive caster (manual rack)
Why positive camber? It's not that I don't trust the experts at Fat Man. I'm just curious. In my (limited) brain it just don't make sense with positive camber...
Old 04-18-2010, 03:42 AM
ericnova72's Avatar
More for Less Racer
Makes no sense to me either, I would definately call Fatman on Monday and find out if that is a missprint.
Old 04-18-2010, 04:43 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The positive camber spec they are giving sounds like a factory spec for a Mustang II. Go with 1/2 to 5/8 degree negative camber and closer to 2 degrees positive caster for manual steering more for P/S. About 1/8" toe in to complete the picture. The negative camber setting will help reduce understeer in the front end and will help the tires live longer.
Andy
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
1937 ford pickup Mustang II suspension brakes magnum2u Suspension - Brakes - Steering 1 06-24-2006 09:36 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Mustang II suspension theclaw1 Suspension - Brakes - Steering 4 08-03-2004 04:48 PM
Mustang II suspension parts jniolon Suspension - Brakes - Steering 5 05-26-2002 04:04 PM
