why a powerglide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2009, 11:33 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
why a powerglide?
Ok so I see people all of the time that use powerglide trannys on there cars@my local teack...can anyone tell me why there so popular?
Old 09-14-2009, 12:25 AM
techinspector1's Avatar
Wiki Edits: 326
They're light and relatively inexpensive and they eliminate one shift. Most of the racers I have talked to relate that they will work well in a car up to about 2800 lbs. If the car weighs more than that, it would probably go faster/quicker with more gears to lower the ratios of each gear.
Stock first gear ratio on a 'glide is 1.76, so when combined with a 4.11 rear gear for instance, the final drive ratio in first gear is 7.23:1. Using the same rear gear with a TH350 trans, having a 2.52 first gear, the final drive in first gear would be 10.35:1, so you can see how this would benefit a heavier car to have a lower first gear as well as another gear before you reach 1:1 in the top gear.
Old 09-19-2009, 02:09 PM
two cups of tea
Wiki Edits: 2
Thanx inspector
Old 09-19-2009, 11:18 PM
WDCreech's Avatar
Grumpy Old Goat Herder
To use the advantage of a glide, you should have a relatively light car and a converter that will work with the glide.
Old 09-20-2009, 01:26 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Light, strong, and it does the trick. Many drag cars only need the two ratios for the amount of time they spend on the track. All part of driveline ratio tuning and getting the best match for the car.
Old 09-21-2009, 12:08 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
1. not really for road vehicles... note they introduced 3 speed autos when the highway system really got established.
2. They're light as said before, and another thing is with fewer parts (only 2 speeds) they are less fail prone.
3. Everything else has been covered really well.
Old 09-26-2009, 03:39 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
In stock form not that strong but with a few up grades can take a lot of hp. Less moving parts so less hp loss thru trans.
Old 09-26-2009, 10:02 PM
WDCreech's Avatar
Some of the high horsepower pro-mod guys use a glide to tame the launch, so they don't blow the tires off. I have a friend with a 3500# sbc powered "65 El Camino that lunched three TH-350s and switched to a glide and picked up .3 and 2mph, in the 1/4. I went from 9.24 to 8.942, in a 2600# car, changing from a TH-350 to a glide.
powerglide questions pittbull7934 Transmission - Rearend 12 06-29-2009 10:17 AM
Transmission for a v/8 powered trike? Bad Rat Transmission - Rearend 31 02-17-2009 11:57 AM
2 speed powerglide trans 64r1 Transmission - Rearend 2 08-03-2007 10:29 AM
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 09:21 PM
Powerglide, strength, conversion and misc' Venturat Transmission - Rearend 5 01-21-2003 07:59 PM
