Why Residual Valve Needed??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2007, 11:35 AM
When going from a disc drum Master Cylinder to a drum drum braking system, why is a residual valve needed on the disc side of the MC. If the MC is a disc disc, is a residual valve needed on both front and rear to go to a drum drum brake system?? Does the valve install into the brake lines, if not where is it installed.
Old 05-17-2007, 11:50 AM
Last journal entry: Body work
From Willwood's site.
WILWOOD RESIDUAL PRESSURE VALVES:
These in-line pressure valves retain a minimum brake line pressure to help eliminate excessive pedal travel in both disc and drum brake systems.
The two pound valve is used in disc brake applications where the master cylinder is mounted below the horizontal plane of the calipers and fluid drain back occurs from gravity and vibration, thereby causing excessive caliper piston retraction and a longer brake pedal stroke. The minimal two pound residual pressure prevents fluid from flowing back without causing the brakes to drag. With drum brakes, a ten pound valve is used to compensate for return spring tension in the drums. Residual Pressure Valves are made from billet aluminum and color coded for easy identification. Ideal for drag racing, street rod and many off road applications.
lower than the wheel cylinders or calipers.
Old 05-18-2007, 10:35 AM
Residual valve
So if a MC is mounted on the firewall, then you do not need to install a residual valve???
Old 05-18-2007, 12:00 PM
Right, If the master is higher than the wheel cylinders or calipers the valve isn't necessary.
Old 05-18-2007, 08:21 PM
Will I ever get it done?
Last journal entry: Hood
The residual pressure valve is necessary for drum brakes. The seal lips on the wheel cylinder cups only seal one way. The hold the pressure in the system. They will allow air to pass them into the system if the air pressure exceeds the line pressure (absolute not gauge). It can happen. If it does, you will have air in the system and a spongy pedal. A 10 psi residual pressure valve is the commonly used for firewall or under floor MC's on the drum brake circuits only.
The square cut o-rings which seal the caliper pistons on disc brakes seal both directions. So, provided the calipers are below the MC, you don't need a residual pressure valve. If the calipers are above the MC, the liquid head can cause the fluid to go back into the master cylinder, retracting the pistons, causing a low pedal the next time you hit the brakes. A 2 psi residual pressure valve is commonly used for under floor MC's on the disc circuit only.
Most MC's made for drum/drum or disc/drum have residual pressure valves built into the drum circuits in the MC, right behind the flare seal. If you are using a disc/disc MC (or a disc/drum MC on a drum/drum system), you will have to put an external residual pressure valve on the circuit which was intended to be disc but is now drum.
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
desktop dyno needed!!! bobbypantera Engine 8 06-19-2005 01:27 AM
Residual Pressure Valve useful? cboy Suspension - Brakes - Steering 3 03-12-2005 07:10 AM
When is a proportioning valve needed? jpd37 Suspension - Brakes - Steering 2 03-25-2003 09:42 AM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
