Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Why some runs never leave
Old 11-13-2005, 09:10 PM
PimpJuice PimpJuice is offline
Rookie of the year
i have used the razor blade before. do you think it is from using 2000 grit paper only.
i thought once sanded, it was sanded. this not the case then?
so, 1000 grit would flatten the run, where 2000 may leave some of the shape behind?
i am confused.
i have had same issue with sags
Heres a thought.................Don't get a run..................
you paint perfectly do you?
PimpJuice
