Why a spacer between the intake manif. and the carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2003, 09:48 AM
F-1Rodder's Avatar
Post Why a spacer between the intake manif. and the carb?
I have read dyno articles and note that sometimes a HP and Torque improvement comes from adding a spacer, usually some sort of plastic material, in between the manifold and carb.
What are the flow dynamics that explain this result. Why does it work sometimes to produce more power and sometimes not?
Old 03-06-2003, 10:32 AM
unstable's Avatar
Murderator
Post
METHINKS (don't know) that it has LESS to do with the flow dynamics and MORE to do with cooling off the fuel by seperating the carb from the manifold.
Cooler fuel = good.
Hotter fuel = bad.
Old 03-06-2003, 10:43 AM
Post
it also gives the fuel more time to drop and helps with mixture. it also gives you more plenum volume which alows each cylinder to have access to a bigger gulp of air and fuel.
the reason it somtimes doesn't help is because of the head cam and intake combo itself. if the amount of plenum is enough for your combo adding more won't help
Old 03-06-2003, 10:51 AM
bullheimer's Avatar
NEVER use credit cards!
Post
sounds good to me. i have also read dyno results in HRM where they said they made less torque/ also agree that making air cooler would always help, it seems! it looks like you have to put one one, run it and see what happens. a $30 experiment.
