Why straight plug heads and angle plug heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 11:37 AM
406chevelle's Avatar
One of these days...soon
Why are there sbc straight plug heads and angle plug heads???
It seem that most common headers accommodate the straight plugs.
I have chance to buy a set of AFR 210cc angle plug heads for a good price, but the available headers for angle plugs seem limited for a 72 chevelle.
Any pros or cons to straight versus angled???
Old 03-19-2006, 11:45 AM
MI2600's Avatar
Member# 3287
I have heard (no personal experience) that the angle plug heads add a very slight amount of oomph at high rpms. The theory is that the plug is pointed toward the exhaust valve for better combustion.
My take is that if they were so much better then all race heads would be angled.
Old 03-19-2006, 12:07 PM
I always thought you could order either because of header clearance issues.
Old 03-19-2006, 12:18 PM
poncho62's Avatar
Wiki Edits: 5
The angle plug heads were an experiment from GM in the late 80's, I believe. On a street car, there is little or no advantage to them.
Old 03-19-2006, 12:21 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Plug angles are coordinated with chamber shape for better flame travel, etc. Time passes, ideas change, and so does technology. Some heads also have the plug moved over sideways to center the spark tip. Ideas like extended tip plugs have the same effect to help center the flame travel.
In reality, there is only minimal real world differences in most all the heads.
If you can't get headers, don't get the heads.
Old 03-19-2006, 12:33 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I have used both on my nova. I couldnt tell any differance in performance. But I will never own angle plug heads again. Because they were a nightmare to change plugs in my Nova.
Old 03-19-2006, 12:36 PM
automotive breath's Avatar
AFR has part numbers for both straight and angle plug heads. Because very few people order the straight plug 210 SBC head, request for them must be handled at the beginning of the machining operation (special order = longer delivery times). The result is fewer used straight plug versions.
As for the advantages of the angle plug on the street, it's not enough to notice.
406chevelle, The AFR 210 is an excellent head, if you can make them work, buy them your 406 will love it.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
angle plug heads and s-10 mychevystang Engine 7 03-21-2005 02:37 AM
Will Angle Plug Heads Work? strikingthematch Engine 5 10-27-2004 06:10 PM
What heads for a 350 have the spark plug wires on top? batman09 Engine 13 09-25-2004 10:52 AM
headers for a 83 chevy 4x4 with sbc brodix angle plug heads jrtraveler79 Engine 1 04-23-2004 11:04 PM
