why taller tires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2007, 02:38 AM
Last journal entry: beginning of the 340 challenger
why taller tires?
sorry for a dumb question, but what are the advantages of running taller tires? covering more ground? i know that you would need the proper gear set to run with the tires, i just wanted to get a clear explanation of what taller tires do for the car as far as performance and what not
thanks
Old 07-24-2007, 07:40 AM
327NUT's Avatar
Not a dumb question, taller tires may be an advantage or disadvantage, just depends on your set up and vehicles application. Granted a taller tire turns less revolutions per mile but a possible gain in gas mileage will most likely be negligible.
Example...On my F-250 4x4 I went to 315/75/16 Pro Comps because I got a great deal on them. They looked good and rode smoother but I lost 3 miles per gallon because they were a 50 psi tire. I went back to the 265/75/16 E rated 80psi tire. Also bigger tire/wheel combo puts more strain on your suspension and brakes. If you're doing it just for looks, make sure the size FITS your vehicle.
Old 07-24-2007, 12:02 PM
well i put some 275/60/15 on my car because i was running 3.91 gears... so im guessing the bigger the gears the taller you want to run the tires to keep rpms down?
Old 07-24-2007, 12:51 PM
techinspector1's Avatar
Wiki Edits: 326
Exactly right. For the same rpm's, transmission final gear ratio (1.00 with a Powerglide, TH350 and TH400 for instance) and ring /pinion ratio, a shorter tire will produce slower vehicle speed while a taller tire will produce faster speed. By the same token, for a given vehicle speed with the same tranny and rear, a shorter tire will cause the motor to rpm higher to maintain that speed while a taller tire will cause the motor to rpm lower. Here's a calculator you can play with.
http://www.csgnetwork.com/multirpmtirecalc.html
Old 07-24-2007, 01:05 PM
wow thanks
Where can I get these BFG tires? rusttorod Hotrodders' Lounge 6 04-16-2006 01:20 PM
Pin Heads at Sams Club tires Landau454 Suspension - Brakes - Steering 16 02-15-2006 02:15 PM
Tires for 4" wheels dh79 General Rodding Tech 6 07-27-2005 07:37 PM
help slammed my chevy now tires rub vortec327 Suspension - Brakes - Steering 3 07-22-2003 11:18 AM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
