A nap between epoxy and surfacer might be a good thing. Follow the tech sheets as to recoat windows. As for the clear, the cheaper the clear, the less apt it is to be forgiving on your recoat times. If you're spraying clear in less than ideal conditions such as the high end of the activator's range, you need to hustle up and keep the recoat window short, feel the paper where you started clearing, if it is tacky, not wet, put on the next coat of clear starting then. if you allow too much time, you'll end up with dry spray any where your pattern overlaps like in the middle of the upper panels as far as you can reach and the patterns overlap. I hope this makes sense.
Good luck,
Chip.
