Why vacuum on a timed vac port at idle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 09:07 PM
Can anyone let me know what would cause a timed vac advance port to have vacuum at idle rpm (850)? This is on a holley 600 4160. Thanks!
Old 06-02-2008, 09:12 PM
Greg T's Avatar
www.krusinklassics.net
Throttle plates open too far....leaking base gasket.....cracked carb base.
Old 06-03-2008, 08:28 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Had an experience with the exact carb on a friends engine with a lumpy cam. I did all the things one would normally do for a 'tune'. Found the timed port still pulling almost as much as straight manifold vacuum. I tipped open the secondary plates a little, then closed the primary plates. Did the trick for this one. Went back through the idle A/F mix with a vacuum gauge and picked up more response and way better drive-ability.
Old 06-04-2008, 07:05 PM
I think the cause was the throttle plates too open, good call you guys. I cracked the secondary plates, turned down the primary plats, and no more vacuum on the timed vac port!
454 Ignition Timing Question leejoy Engine 58 09-13-2008 08:40 AM
terrible gas milage help!! hddave1 Engine 124 03-31-2008 10:57 AM
350 sbc will not accelerate j_sirnio Engine 15 02-06-2008 09:55 PM
Vacuum Advance for a Galaxie, HELP 63 Falcon with a 350 Engine 27 09-30-2005 07:54 AM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 05:39 AM
