Why will car not start?
Changed battery on Chev Aveo 2007.Since then car will not start. No spark no fuel car just cranking. All other electrics working fine. car locking and unlocking ok by remote but will not start. Please help
You are probably going to have to re-set the computer, It was probably un-hooked to long JMO
Cole |
The computer would go to baseline settings and it will learn as the car runs. You were working near the battery, that is the first place to look. Also look at the fuses for the ECM.
Artificial Intelligence is no match for Natural Stupidity Chet |
If the electrical system checks out, check to make sure the camshaft is rotating as the engine turns over. |
T-Bucket is correct it could be a fuse ex-specially if there was anything on when you replaced the battery.JMO And X2 what Cobalt said also.
Cole |
The fuses in the engine section have all been removed and tested as well as the fuses on the driver's side panel.All electrics works fine except that something is inhibit the consent to give a fuel and spark command.The battery was removed for almost 24hrs while swapping with a new one.Engine is turning fine.How do I reset the computer, any software available or must take it in to dealership.
gombera |
The only alarm displayed is empty tank, when the car is more than half of tank with fuel.
Gombera |
Anyone happen to notice 'gombera's' address?
It's more than likely the immobilizer portion of the ignition system that must be re-set by the dealer. Likely, foot on brake pedal, key switched on/off seven times, put on left signal lite. |
Chev Avoe not starting
Many thanks for the resonses guys, took it in to the dealership no luck. They reffferd it to a outsourced sparky who claims he 'repaired' burnt computer box in engine compartment. One week later packed again, took it back and he claims he repaired same.
| How Do You Start a Car Club, Picking a Name and Legal Stuff | CLSSY56 | Hotrodders' Lounge | 4 | 03-01-2008 08:10 PM |
| a true story abount my first car | chopperdave70 | Hotrodders' Lounge | 7 | 01-26-2008 06:13 PM |
| Sometimes my car won't start | 55ford | Engine | 10 | 12-19-2004 01:55 PM |
| change modular car will start shut off and won't start back up | Ramman | Engine | 1 | 11-26-2004 08:20 PM |
| Story time. | Halloweenking | Hotrodders' Lounge | 17 | 05-19-2003 10:16 PM |
