Why won't my battery stay charged? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2010, 05:04 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I can't seem to figure this one out.If I let my car sit for a few weeks without starting it,the battery will be dead when I go to start it.I have new battery new alternator new mini high torque starter can't seem to find a draw.I disconnected the negative battery cable from the post&stuck a test lite between the post&cable&nothing.Any ideas?
Old 05-03-2010, 05:45 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
You will want to remove the positive + cable and take the reading between those two points .. cable and positive + battery post... test light or meter same same ... removing the ground opens the circuit ....
Old 05-03-2010, 05:50 PM
T-bucket23's Avatar
Wiki Edits: 26
Either cable will show the same results. If there is a draw it is equal on both the ground and positive cable. It is actually safer to do it on the ground cable.
To the original poster, have the battery tested, just because its new doesnt meen its good, especially if you are sure there is no draw. A wrap around current probe is a better tool. When you disconnect the battery you could be releasing whatever circuit is drawing
Chet
Old 05-03-2010, 06:03 PM
two cups of tea
Wiki Edits: 2
Any idea how else to check for the draw?
Old 05-03-2010, 06:37 PM
Using a multimeter, preferably a digital type, (if you don't have one, borrow one from a friend), disconnect a battery cable. It makes no difference which one, since the current thru the positive battery post and the negative battery post are equal. Set the multimeter up for measuring current, and touch the meter leads between the battery post, and whichever cable you disconnected. If there is any current draw, you'll see it on the multimeter. Then by process of elimination, you can pin it down. As a precaution, many digital multimeters have a current measurement function that's limited to 10 amps. If you somehow exceed that value, you will probably blow a fuse in the multimeter. If that happens, the multimeter will indicate zero amperes. Just avoid turning on any high current circuits while you're checking things out and you should be OK.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
battery keeps going dead, i need some f#*%&!g help 406 ss monte Engine 21 10-12-2006 03:43 PM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
Spacers behind fan? moodier General Rodding Tech 14 10-06-2005 08:08 AM
Battery problem? evltwin Electrical 11 04-10-2005 06:45 PM
